Dan H chided me for wishing this power gain in a previous thread.
He suggested the inside of a Lycoming engine wouldn't support the kind of internal airflow required.
So I got out my trusty educational core engine case. The front 2 cylinders live in a closed crankcase chamber, with a 2" per side triangular hole under the main bearing. all the oil drain back to the sump, plus all the crankcase blow-by must pass thru this hole.
Bear in mind the front 2 cylinder's pistons go out and in together, opposite of the rear pair.
So the front & back crankcase chambers are pressurized and de-pressurized opposite of each other during each crank rotation.
Flow must fluctuate thru that little hole, with a constant average flow going aft with the oil drain back to the pan + the blow by flow thru the rear chamber toward the crankcase vent.
My point is that you can't get fluctuation free 'Low Crankcase Pressure' like an auto engine with a common crankcase.
Crankcase compression is going to happen with this old fashioned design engine, the higher the RPM, the less effective pressure averaging can occur between chambers.
I believe Dan's conclusion, and now mine, is: Large power gains from V8 auto engine tests won't be attained.
