Old 02-11-2018, 10:28 AM
Jolly Jolly is offline
Default CPS oil filter wrench
Bryan at CPS got me to try their new oil filter wrench. It's stainless and makes oil filter removal and install a breeze.
Old 02-11-2018, 06:26 PM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
https://m.cps-parts.com/catalog/topa...clickkey=23192
This one?
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 435 Hrs on the Hobbs
Old 02-11-2018, 08:44 PM
The RV-12 exhaust system is purposefully designed to assure enough access clearance to allow using a simple and inexpensive strap type filter wrench similar to this....
If the filter was installed properly, this type of wrench has no trouble removing it.
Nothing wrong with this other wrench that Roger is informing everyone about.... perfect for those that prescribe to the tool of the month club (I.E., have to always be buying a new design tool because it must be better, right?)
Scott McDaniels
Hubbard, Oregon
Old 02-12-2018, 10:02 AM
I bought an assortment of oil filter hex sockets for 3/8” drive at Harbor Freight a few years back. One of them slips right over the end of the filter. Works great.
Old 02-12-2018, 10:55 AM
DaleB's Avatar
DaleB DaleB is offline
I found that the same wrench I use for the filter on my Harley works great for the RV-12 also. I use a 3/8 extension and flex handle with it.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 02-12-2018, 12:19 PM
todehnal todehnal is offline
I use the cup type that fit on the end of the filter. Simple, cheap (under $5 at Walmart) and fool proof. Generally, I don't even need to add the 3/8" hex drive to the end. Just slip it on, give it a twist, and off comes the filter. But if it is a little stuck, just use any 3/8" square drive for a bit more leverage........Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 02-13-2018, 07:15 PM
Tom, you must have Schwarzenegger’s arms to get that off with your bare hands!
Old 02-14-2018, 05:23 AM
Yeah, they get pretty tight. Slow steady tension helps, but a 3/8" hex drive helper makes it a piece of cake........Tom
