Old 12-29-2017, 04:20 PM
mwardle7 mwardle7 is offline
Default S-1207 Spinner Pitot Bushing
I can't seem to get Loctite 243 to hold the spinner pitot bushing in place over the long term. This is what the manual suggests, and it doesn't work well for me. Anyone else having this problem, or have found a better solution:
Also, does anyone know what material the bushing is made out of?
Old 12-29-2017, 04:44 PM
AZLeeJay AZLeeJay is offline
Mine came loose at 400hrs and I used pro-seal to reaffix it, that was only 25hrs ago but I think it'll hold.
Old 12-29-2017, 06:09 PM
Loctite thread locker only cures between metal fasteners where it is not exposed to air (anaerobic). It will not cure when used between plastic parts.
Joe Gores
RV-12 Flying
Old 12-29-2017, 09:09 PM
I epoxied mine.
Old 12-29-2017, 10:53 PM
DaleB's Avatar
DaleB DaleB is offline
Mine departed somewhere around 200-ish hours. I don't know what the original builder used to secure it, but I used Proseal on the replacement.
BTW... I am just baffled by the recommendation to use blue Loctite. I'm sure there is some reason someone came up with that, but I can't imagine what it might be. It just seems like about the last thing you'd want to use for that application. Loctite does make some adhesives that would probably work fine, but 242 or 243 aren't among them.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 12-30-2017, 07:32 AM
yankee-flyer yankee-flyer is offline
Default I used epoxy after the first one
came loose at 350 hours
Old 12-30-2017, 10:55 AM
Jetguy's Avatar
Jetguy Jetguy is offline
Originally Posted by RFSchaller View Post
I epoxied mine.
Me Too! Still working great at 1050 hrs.
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Johnrv12@icloud.com
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
Old 12-30-2017, 02:16 PM
John-G John-G is offline
Was surprised to find my bushing came off during the first week or so of testing ... I too had used blue Loctite as suggested in the plans.
Ordered a new bushing and installed it using a thin coating of Pro-Seal on it and made a thin bead on the backside with a syringe ... so far all is well. Actually found the one that flew off a week or so later ... seemingly unscathed. So now I have a spare.
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2019
Old 02-17-2018, 01:00 AM
cyamaha2007 cyamaha2007 is offline
Mine came off also, we used 243 to attach it the first time but now its epoxied and holding strong.
Old 02-17-2018, 04:23 PM
Vakashi Vakashi is offline
Default Loctite 7649/7471 primer/activator
1. According to the various downloadable Loctite user guides, most Loctite threadsealing products, such as Loctite 222 and 243, must be used with Loctite 7649 or Loctite 7471 primer/activator on inactive surfaces. The only active surfaces listed are brass, copper, bronze, or iron. Inactive surfaces are aluminium, stainless steel, etc., and obviously include our spinner and its bushing, both being non-metallic.
2. A primer/activator is also required when the thread gap to be sealed or locked is large, a relative dimension, but one that I think would apply to the bushing/spinner gap.
3. A primer/activator can be used when temperatures are very low to speed up the process.
Assuming that Loctite 243 has been used successfully to bond the bushing into the spinner, or it wouldn't be in the KAI, my question is, 'have any bushings fallen out despite using a primer/ activator?'
