Noah
For those who used Sika on their canopy, did you fiberglass in the front intersection or did you strictly use Sika (no glass / epoxy)? Reports are that the Sika sands nicely and is easily shaped with 120 grit sandpaper which allows for a nice fairing at the front intersection; other reports are that the canopy gets a lot stiffer after the addition of fiberglass at the front intersection.
My concern is that the stiffness might be insufficient without the glass, and also that the strength of the epoxy is significantly higher than the Sika. Any comments??
