aparchment
Hi folks:
Quick question, I am preparing to install my steps. The instructions say to cut a 1.5" hole in the fuse side, but if I only cut a 1.5" hole in the fuse skin, the weld on the step mounting plate will interfere with the hole, and the step mounting plate will not fit flush with the fuse side. I think I need to open the hole up at least 1/8" more, either that or grind down the weld. Grinding the weld it seems would compromise the strength of the part.
How have others handled this, and how has your solution performed?
Thanks!
Antony
Thanks!
Antony
