I'm not an electronics guru either but I know how to get in touch with one. Read on.
A bit more info for you. If you haven't got a copy of the
"Aeroelectric "Connection" then get one on order. It's a tech manual but it's written in a way that makes for an easy read.
BUT FIRST! Take a look at
Appendix Z of "The Connection", Power Distribution Diagrams and Options. The schematics toward the bottom will give you an idea of what else you will need to order with your copy. For those that haven't seen this in a while, the schematics are updated and re-numbered. Z-11 even has an "automobile alternator" in it. A big change in thinking for the author.
Now that you have a better idea of what you need, surf on over to
B and C Specialties where you will find most of what you need to make your install.
Things like current limiters and ammeter/load meter shunts. You will even find the "OVM-14" which gives you the overvoltage protection you will read so much about. This "quarter-size sealed module will tame the meanest runaway alternator in milliseconds."
The one item you will need that they don't have is the
voltage regulator. HUGE thanks to Sam for his timely post of the link to Autozone. I picked mine up today, 10 bucks! THANK YOU SAM!!!
One more thing, Robert L. Nuckolls, the author of "The Connection" is easy to get ahold of through his forum on the Matronics site. So if you run into a road block, you can talk to him.
