Basically, yes, just a logbook entry that you have tested something and verified that it performs as it is supposed to. Anything that was not tested during initial Phase I or was added, repaired, or modified since Phase I must be tested by reinserting the AC back into Phase I.
If you complete Phase I, but haven't performed any aerobatics, you can later, place the plane back into Phase I, perform manuevers, sign them off in the logbook, then perform them legally in Phase II.
Similarly, you can add equipment (IFR stuff), return the plane to Phase I, test, prove it works properly, sign off, then return to Phase II and perform these tested things legally. Placing your plane back into Phase I can be done anytime, voluntarily, to test new items, repairs, modifications, modes of flight, etc. Phase I means you test these items just like you did in the initial Phase , in your test area and solo. Generally the reinsertion to Phase I lasts 5 hours or until proven. Then the portion tested is signed off to satisfy the appropriate Fars. I do not know this for certain, but I believe IFR equipment may be tested using a safety pilot on board, since you are not actually testing structural parts of the plane. It seems this would be the best way to prove the functionality of IFR equipment. Having the builder testing under the hood while a safety pilot watches out seems like a reasonable way to test.
I attended an EAA "Testing Your Experimental Aircraft" seminar and this is what I was taught during that seminar. As the builder of an Experimental AC you have a lot of latitude, but responsibility and common sense must also be factored in. Signing something off as good leaves you, the builder, subject to any liability that any other AC MFG would be subjected to.
Roberta
