JurgenRoeland
I recall with the elevators on the empenage, that it was good practice to put RTV at the end of the stiffeners before rivetting to avoid skin cracking on longer term.
Does the same thing apply to the ailerons. The build process is almost the same so I was thinking that the stiffener problem on the elevators might also apply here.
Did you guys also put RTV inside the ailerons at the end of the stiffeners near the trailing edge ?
