tomhanaway
116TP had its first light today. All went pleasantly smoothly.
Shortly, I'll be calibrating my AOA linked to Garmin g3x touch( dual screens).
I have flap position indication on my PDF.
Does the Garmin system (all Garmin avionics) store the settings dependent on flap position? Obviously, the stall speed is higher clean than full flaps.
So if I calibrate the AOA at each flap position does the AOA give stall indications based on flap configuration?
Tom H
Tom H
