Old 09-22-2018, 09:03 AM
pilot28906 pilot28906 is offline
Default Engine Hanging Problem (bolt spacer)!
We just started hanging the engine and the spacers that the bolts go through for the mount are too small. The -7 bolts will not go into the ID of the metal spacers. Do the spacers get reamed or do I have the wrong spacers? Any help would be appreciated.
John
John Johnson
Murphy, NC
RV7
Old 09-22-2018, 09:08 AM
Mel's Avatar
Mel Mel is offline
Sounds like you have the wrong spacers. They should slip right through. They should not even be a tight fit.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 09-22-2018, 09:29 AM
The spacer part number matches the drawing. The I.D. of the spacers are .4255". How large is the ID supposed to be?
John Johnson
Murphy, NC
RV7
Old 09-22-2018, 04:23 PM
jrs14855 jrs14855 is offline
Default Bushings
The generic id for the bushings would be around .447. AN7 bolt would be around .435/.436. AN bolts typically measure about .0015/.002 under the nominal size. Size of the spacer is not critical, only the length is important. You can make some spacers from 9/16" x .058 4130 tubing.
Old 09-22-2018, 05:28 PM
I reamed the ID and they worked fine.
John Johnson
Murphy, NC
RV7
