Old 08-07-2019, 07:33 AM
pappa pappa is offline
Default Spar blocks
Starting on fuselage. My plans say to make blocks. They MUST be 1.438 inches to match the thickness of the spars. Just happened to put a dial caliper on the spars. Well, they all read thicker, The thickest reading.....1.448. .?????. How once everything is locked down and riveted, can a solid piece of metal that is larger than the hole it is supposed to go in, actually go into that hole. So, how did you'all do it. Your thoughts are greatly appreciated.
Old 08-07-2019, 09:44 AM
longranger's Avatar
longranger longranger is offline
There’s more flex in the center section than you think. When building up my F-704 bulkhead I used a set of blocks from a previous RV-7 builder and even added a couple of layers of masking tape to give myself a little cushion. When I measured the center section and spar stubs in preparation for mating the wings to the fuselage for the first time I was horrified to find that the spar stubs were 10-15 mils thicker than the space in the bulkhead. I did some research and found that several builders before me had the same issue and ended up not having a problem mating the wings. Per the manual I lightly beveled the ends of the spars and greased them and the center section. It took a few minutes of jockeying to get the spars lined up with the center section, but once we did the spars slid right in.
http://www.mykitlog.com/users/displa...g=251539&row=9
Miles (VAF# 1238, Paid up as of 2018)
RV-7 TU 904KM (reserved)
Wings Fitted and Finish Kit on site
Construction Log
Picasa: Empennage Album, Wings Album, Fuselage Album
1955 Cessna 170B flying since 1982
'To get something you never had, you have to do something you never did.' -Unk.
Old 08-07-2019, 09:45 AM
N804RV's Avatar
N804RV N804RV is offline
I bought the 1.445" spacers from Buller.
https://bullerent.com/experimental/spar-spacer/
Ken W.
Mount Vernon, WA
2019 VAF Supporter
Old 08-07-2019, 05:48 PM
I used plywood. Doubled the pieces shaved to required thickness and left there for couple years. Drilled them later to secure the fuselage while transporting to the airport.
Old 08-07-2019, 06:57 PM
wirejock's Avatar
wirejock wirejock is offline
Default Buller
Same here. Worked great.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/03/2019, plus a little extra.
Disclaimer
Old 08-07-2019, 08:13 PM
bruceh's Avatar
bruceh bruceh is offline
I had a scrap piece of thin walled electrical conduit. I cut 4 pieces to rough length with a tubing cutter, then chucked it up in the drill press and filed it down to the correct length. Measured everything with calipers until it was a perfect fit. Wood will potentially change its length with humidity. These spacers worked great and didn't take up any unnecessary space in the spar carry-through area.
Bruce Hill
RV-9A N5771H flown over 700 hours!
2019 VAF donator
EAA Tech Counselor, Build assistance - canopy/tanks/fiberglass/electrical/repairs
Old 08-08-2019, 12:08 AM
Wunderon's Avatar
Wunderon Wunderon is offline
PVC pipe cut and sanded to length.
Dave Grimmer
RV8 N46LG for Lynda
Edmonds WA
paid 2019
