I was sent this picture by Ed Wischmeyer, who asked me to share it here in the hopes that it might make folks go have a look at their rudder cables to make sure they don?t have a similar problem. This was on the -8A that he bought (he didn?t build it) ? apparently, the front of the cable end barrel jammed on the rudder stop in flight. Ed says he tested both left and right rudder before flight, and this happened in the air.
Curious about how this could happen, I stepped out to the hangar and took a side-on shot of my RV=8?s installation:
I instantly saw the problem ? Ed?s rudder stop is installed quite low, putting the stop directly in the path of the cable. I didn?t go look up the -8 plans, but I am pretty sure mine are installed per the drawings (although shaped to actually work right). Something folks should check ? I am sure Ed?s airplane has flown for many, many hours this way ? but it only takes once to get an exciting ride into the nether regions of your airport if the rudder jams.
