I ran RG-400 to both wing tips, and also wire for position lights, strobe lights and landing lights.
I used 3/4" pvc light weight irrigation tube for conduit, all that wire fit in it. I have an ARCHER Nav antenna in the left tip, and the 3 light marker beacon in the right tip.
I drilled the ribs for the conduit right behind the main spar, low near the bottom skin. I wouldn't do that again, it was hard to get the wires into the fuselage after I put the wings on. Maybe a spot farther aft would be better.
I'm installing the position lights, strobes & landing lights in the wing tip.
No matter, if it's too much heat or the landing light is unsatisfactory, I'll switch to a Ducworks landing light later. Because the wires all terminate at the wingtip with a service loop, I can always build in the duckworks system later without a splice.
