Old 06-10-2018, 12:11 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Originally Posted by Walt View Post
My idea covers failure of both powerplant and electrical systems plus propeller malfunctions too...
Turbo Subaru EJ22, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 420 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 06-10-2018, 12:14 PM
rv6ejguy's Avatar
Originally Posted by rocketman1988 View Post
What the failure mode on that system?
Yes, I see, we'd need independent ignition and fuel systems for each turbine plus a separate door and actuator system to drop them into the airstream independently. Plus a fire warning system, fire extinguishing systems and N1 indicators...
Old 06-10-2018, 01:23 PM
rocketman1988 rocketman1988 is offline
Default and...
Then we would need to look at the switches. contactors, and relays, too.
Also would need to account for insulating the cavity that contains the turbine for heat, sound, and the potential for an unconfined turbine failure...not to mention the the separate fuel system for the turbine and preventative measures to ensure that no kerosene gets into the main tanks or gasoline into the turbine...
That's just a short list but it's enough to get started!
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Dues Paid 2017,...Thanks DR+
Old Today, 02:44 PM
DanH's Avatar
DanH DanH is offline
The NTSB published a final report on the SQ-12 engine power loss:
https://app.ntsb.gov/pdfgenerator/Re...Final&IType=LA
Short version: All the injectors on one circuit breaker.
Dan Horton
RV-8 SS
Barrett IO-390
Old Today, 03:17 PM
rv7charlie rv7charlie is online now
Well, duhhh.
It would be amusing to think about all those guys who poo poo alternative engines, and then throw something like that, with such obviously un-thought-out design work, on a 'traditional' engine and call it good. But for how scary it is...
Charlie
Old Today, 04:42 PM
DanH's Avatar
Let's treat the information in the spirit of aviation safety culture...lessons to be learned, "There but for the grace of God", etc.
Too often, "duh" is only obvious in retrospect.
The docket should be interesting, when available.
Dan Horton
RV-8 SS
Barrett IO-390
