Larry DeCamp
I need to decide if a shotkey diode is needed for the aux battery on my electrically dependent ignition. It would isolate the battery from any demand in the battery or main bus system. It does drop the charging voltage a little. With B&C 410H alternator max charge amps should not be a problem. Dan H ( highly respected) has suggested ?a hot battery bus approach ?. Less is usually more, so what does a diode do for me in this scenario ?
