Wing Stand Question
Surfdoc
Active Member
Does anyone have an illustration of the outboard rib attach to the wing stand (slow build). More specifically the below instructions as I am having an issue visualizing, but I have been in meetings all day that that could play a part in my "numbness of the mind".
"Clamp or bolt the wing skeleton to the horizontal arms of the H-frame. To provide a mounting point on the outboard end of the wing, drill and bolt a temporary 5" long piece of aluminum angle, (visible in Figs. 7-4 and 7-5) parallel to the spar web, to the outboard rib with 3/16" bolts."
I appreciate the help!
Here is what I did, need to drill a second 3/16 hole in each outer rib and if you are enlarging the tooling holes for conduit to not drill them in the outer ribs.
I have a spacer on the rib for clearance between the skin and the support bracket. It's about an inch between the rib and support bracket.
VEDXOcWT3Opdv18NgcErphIy5braZ_BU1Pds46NJHmuXP7wN2waeopQSSR59RXDKZnyYrYEc6WiXZJ-yWrH6969gcPCbVt3Kie8mRUIuDMDD6dp23hx6J0kAp6vxKP6JYelmzZe-MMzS3RceiGCcFATCN3X4gwh-3BqQHFLgUKjO97KB815hgZvDq7uodWTYHRYYYgo9jxoHSVIocrY9InLbSNMJ1lxhhi5Y2-0UdxYRQlcb_mWEF0y_x_b7pdejrd7_e5qIafwRtiyPEP6YBEaNA2EBTs2tIQZG3T8XuvZvveTDV0fHnFp_x8SwZAg-bjunYl5odORcUeeniV0BVYRJCNf19Nmze9rhsn8o0XonNa3lyIEA12eYgVUs0O8SCcXp4DS5ex89BkdSyBc5jmPRJxfM0tJ2JUIv6pGi_u3y7Fq0mTGD4gM6HgN2G3Zf4inbRB8jm7wO7zK6HpsQ28_D3fbfWkUfwx28Ukpct6r1mf2IpuNQquLN0z5WUA7mcw_yvvnZsuYYk-d0ketAlWYnoYmqzX72Va5Ey1y9SBh9zevkcsRgG2HUcCHAO9LB4fFr2EGwSMearJAAN1xGvEWxkJxXpXm3ZLzR6nXUgXif6yp7AYlsnPu2-pw9GnqzMul-fAZd1lZSFEoEhYbhIy6Y=w876-h657-no
9N1XH0bbqoWy_VVx3snkA7m4h-100lKY1ZFwWyPSLLgdiKljR751Wxm7wI4zQwUdxLgx8IwoqqkFj2HN_pOAqrGEXUo58FFTBIiitU9DNmgFDJtYBMfQz9xbrTvq27ug4cc2qxSdKHOLSWbM1F1FkjHOtEKHBefJ2eDTTjaHPwJD_QVGUHZZ9XTIREZDcvVMtE9QclQR4lJbPz5JVe8MNIpFU2fEKY04pepaOTtbVCxlksG4-ZhU31LAG0n3Cgh3EbFLnwqix4FgCgP8i-V7YulsPRHjbyi5RcG7oo6W6b8HuOP6PX2hyz_cvTmhBTwFLiGIG1-_X9I8ifCuZSODoDQr2Vbh_q_t7odEd42psK02IiQwpOP_G4QMMcd1RNJ2Mlm_Qyu0NlWjOkpZq-bunSkz-AnkkjY7eb6av9yXnKXeZ5wpjyzM0DYLvf-CEijz8c1Z1RQZfW401sYaRvCZUxfRLqhdE4CHPZV0_SV3IGdx3GeMD9_MPxLsfTuQCYwSSrroTE5xrDV3Ur0Kvsrm96wiTGwS00rY-ozIyj-0QRW6D8Qp9lEKIKqqONfztmdJ49gotwigkUlpHk0VkUCNoNMZL2Q8Cu1_ORqRw7BkHfuJkxd-_qXxPB-NYcT6614hOAUId574GHJnBn_vTxr38n3i=w876-h657-no
-CS9idqUFwQ-KFf28jrpsr5DUWy2t8w90T1DgxWRWxjqKv8XXjp3G-By-SnZLovUjOXRfdlkqW_Qaijoh0GrQBJZHeYG5Wrnz2FjNWjdDpuTNL1eOrbLHMKxYBVqXYRB0dJ_owBeOdn0Et7n_RD0-U_l9JQsDikcKr_VYx-VKG7zpL2D1gDcgvjp_VopfM9Ja1a4uxoYmbAKwXEuekhBZ8oIoT61XRqb5q1YceHfxQYRzv0Axx-r3dbYAhHyZt7PQKFDV9COxhrwUcBIgjB48DIxf2cr5dEUIRNmcIrDFT9nyyko3XVKAEE_Jkygaf2kFY0mL9X5S-GKyUEQM8Nu6ntyiPtCg9js38NzL9R4pDe7yennSWCS-g4QcOlwS2Frg-TjF8_c1jrMAciCJthZ44h5BaECy4Yl6-C9pzyC4oxbW6zwh6vpz5PA37iNfBH4gyw9KrFixqD5oJV6FT_xUIZsWJdBLESr-N921_YKXycBk1tkcRNvsidBF2w6NHyVQaJcLDdivfqbK15AbGPHc0-ZnDOe151a8Zs9ohViS30LfXGkA4nX03pqgt1BWcVs_HTft-NGHgpwcxqpVxBdLCYJFpzsMIC5THVQrQcATjB8E8d7KVkyjKtZ1i7MAvx0n2HAMm71YQdGNEoHUh2acDJt=w876-h657-no
Wing jig
Kinda depends on the jig. I built steel jigs. Quite a few photos on my blog. Wing page.
The side with the spar bolt holes just got clamped over the frame.
The outer side gets the angle and that gets clamped down.
