Lonnie I. Rush
Member
I remember someone posting information on fuel storage and transfer for auto gas for RV 12. Has anyone come up with a reasonable answer to this. My airport has only 100 LL.
100 gallon capacity, 12v pump and battery, dual filters, and a metering gage so I can charge my buddies what they burn also.
Larry,
Are there any legal considerations to transporting that much gas on a trailer?
--Bill
If you can get by with small storage you might consider the Flo-Fast system: http://www.flofast.com/
The picture is of a 15 gallon jug. I have the two 7.5 gallon jugs option. You can lift a full 7.5 gallon jug fairly easy to load it into your truck at the service station. Most of my flights are 1.5 to 2.0 hours so usually one 7.5 gallon container is all I will need to refill at the pump. A significant benefit of this pump is that it can be rotated backwards to defuel the plane. You can order a 6' hose extension that will reach the bottom of the tank for this purpose.
There is a long thread here that discusses a lot of refueling options.
How do I load a 20 gallon drum which weights 120lbs in my Prius ?
For those of you that have the Bykas fueler, I have a question. I contacted Bykas and learned that the 30 gallon tank was pressured tested to 10 psi and they said that the unit usually operates at 2-3 psi. At this low of a pressure this would only allow the difference between the fuel level in the tank and the fill point on the plane to be 6-9 inches. At 10 psi it would be 30 inches.
Can you utilize all 30 gallons or are you really only able to utilize the upper 15-20 gals?
Of course my math could be wrong also.
Thanks in advance.
I just realized the error in my math. Thanks guys. 1 psi isn't 12 psf, it's 144 psf, so 2 psi will be 288 psf. Gasoline's density is about 45 pcf. So 288/45 is about 6 feet. Now it makes sense.One PSI equals 27.7 inches water column. So 1 psi will raise water 27.7 inches. Gasoline being lighter will go a little bit higher.
We have been using this fueling system for a few years now.
One modification I strongly recommend is to add some type of inline filtration.
Either in the pickup hose inside the tank or the nozzle hose.
n.
During my Annual in April, I plan to also install an airframe grounding lug. I think the muffler/exhaust pipe are not a robust airframe ground.
Since I am already fueling from behind the wing anyway, I just use the tail tie down ring for a ground connection.
The difference between avgas and auto fuel from a corner station in regards to cleanliness is dramatic. Even though there seems to be inline filters on station pumps, the storage tank will still build up a lot contamination.
Larry,
Where did you get your hand crank pump? Your set-up looks like something I would use to fuel my RV12.
Larry,
Can someone post the inside diameter of the filler neck for the 12. I'm expecting to pick mine (S-LSA) up in about a month and am starting to collect "stuff"
I figure fueling system is first.
I'm limited to 5-6 gal containers by airport regs and a bad back!
thx.
Rural King also has a good selection of pumps. They all seem to be labeled with "This product should not be used for fluid transfer into aircraft," though. I'm not sure what the reasoning is behind that - they're approved for gasoline, so what's the issue with aircraft? Grounding? That seems easily solved...Any farm supply store would have them. Maybe Harbor Freight also.
http://www.tractorsupply.com/webapp...10001_CatalogEntry_en_US&searchTerm=hand+pump
