I recently purchased an RV-12 S-LSA. I noticed today that when the stick is neutral, the trailing edge of both flaperons sits about 1/4" below where it would be perfectly aligned with the trailing edge of the outer wing. I've had no problems in flight, have not left flaps extended beyond the white arc, and have double-checked that the flap hand is firmly in the up "detent". If i position the stick so that one flaperon is aligned, the other is about 1/2" below the "aligned" position.
Is this the normal neutral position? If not - is it something that is easily adjusted? More importantly, is there any concern about flying? I need to fly Monday - otherwise would pose this question (and will if needed) to Van's when able to reach them.
Thanks in advance.
Thanks in advance.
