Old 08-21-2010, 05:06 AM
N200PF's Avatar
N200PF N200PF is offline
I had to draw the line somewhere Stein! I'm saving the other video input for the FLIR cam!
- Peter
Peter Fruehling
St. Paul, Minnesota - Based at ANE
RV-7 - Sold
RV-4 - N200PF
2016 Dues Paid - Have you paid yours?
Old 10-10-2010, 11:54 AM
B Cunningham's Avatar
B Cunningham B Cunningham is offline
Default N701VF Panel Pic
Ben Cunningham
RV7 N701VF
Bowman Field, Louisville, KY
Old 10-12-2010, 12:02 PM
shuttle's Avatar
shuttle shuttle is offline
Default G-HUTY Panel - first assembly today
Finished painting the panel yesterday and paint was dry this morning so the long awaited time had finally come to have a go at the very first assembly of all the 'stuff' I've tried to squeeze in. It's amazing how long it takes just screwing things to the panel!!
In the UK it is mandatory to backup glass panels with ASI, ALT and compass. That means there's that extra couple of items to find space for (my compass will be going on top of the glare shield). This layout is the culmination of atleast two years planning so I hope it works out when G-HUTY eventually takes to the air.
The panel is fully home made with all cutouts done by hand (no CNC milling apart from the placards & labelling). The panel itself is about 1.5 inches taller than the Van's standard.
All in all, I'm very happy with the outcome. The only thing I might have a look at is the Garmin 240 audio panel. As it is, it partially masks the labelling of the central switches. I might see if I can rework the 240 so it is flush with the panel.
The only missing item is the remote switch for the ELT. I'm delaying buying an ELT to avoid the battery running down before the plane is finished. The ELT switch will go on the left above the Start Button. I've also got that little bit of space free on the far left just in case there's some super little gizmo that comes along that I just cannot live without
Thanks must go to Paul Dye for the inspiration for the home made Warning Light Panel. It's based on the same channel-within-channel idea he documented here on VAF.
Steve Hutt
West Sussex, UK
RV-7 G-HUTY (not flying yet)
( Tip-UP / TMX-IO-360-M1B / Hartzell 7497-2 / 1x LSE PLASMA III / Dual AF4500's / AF-Pilot AP / 695 )
Old 11-07-2010, 10:51 PM
Sparky's Avatar
Sparky Sparky is offline
Default Update...
Here's the latest pic of my RV-7 Panel... I just finished up most of the electrical/electronics and am about ready to mount the engine. Everything's going very well and all the components seem to be communicating well with each other.
Paul Winkels
RV7 Standard Build - First flight 4/16/2016 - Now Flying!
Old 11-17-2010, 08:18 AM
912ry 912ry is offline
Default N912ry
Still a work in progress.
Old 11-17-2010, 09:39 AM
Brantel's Avatar
Brantel Brantel is offline
Very nice, very clean, very good!
Lean mean VFR cruising machine!!! Oh wait, that is an SL-30....swap out VFR and put in IFR, that is if you have the dual AHRS...
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 11-17-2010, 11:45 AM
Why, yes I do
Old 11-17-2010, 02:43 PM
Brantel's Avatar
Sweet! Very Sweet!
Originally Posted by 912ry View Post
Why, yes I do
Old 11-17-2010, 03:46 PM
Sig600 Sig600 is offline
Those are the 10" SV's right? Thanks for building that panel, I was wondering how two of them would fit! Add a VP-50 to eliminate the switches and a GNS-430 and I've just built my dream panel!!!
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 11-17-2010, 04:53 PM
Yes they are, It's a stock panel too. I was worried that the switches wouldn't fit
but no problems. I would love to put a GNS-430 in there, But no more money!
