Old 07-24-2005, 04:35 PM
Scott Will's Avatar
Scott Will Scott Will is offline
Default tip-up reinforcement kit
Got the skin on the canopy frame... yeah! Now it's time to do the reinformcent kit. How do you make the flanges on all 9 circles? Or are they needed at all? (In one pic I saw the gentlemen didn't make the flanges).
Did you put the reinforcements on when the canopy is off the aircraft - I was thinking that it might twist. Any guidance putting these pieces of metal on are appreciated.
Thanks much in advance!
Scott Will
http://will2fly.com
CFI - CFII - MEI
FLYING RV-7A IO-360 @ KPDK
Old 07-24-2005, 06:03 PM
RV_7A RV_7A is offline
Yes they need to be installed. You will find if you make the flanges on each hole that the reinforcement becomes unbelievably stiff. It almost makes it very difficult to even cleco them into place. They are fairly easy to install and you will find anything you can do to make the frame assembly stiffer is a good thing. Even after you complete the entire tip-up canopy you will wonder how this thing will survive if the wind ever catches it one time.
-Jeff
check out these pages...
http://www.jeffsrv-7a.com/FUSELAGE/05-02-22.htm
http://www.jeffsrv-7a.com/FUSELAGE/05-03-01.htm
http://www.jeffsrv-7a.com/FUSELAGE/05-03-05.htm
www.JeffsRV-7A.com
N808TX
Old 07-24-2005, 06:30 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Scott look here
Here is one builders effort:
http://www.rv7-a.com/tipup_canopy_3.htm
And of course Dan's excellent web site:
http://www.rvproject.com/20030413.html
Cheers George RV-7 slider (I have my own canopy installation issues)
Old 07-25-2005, 06:26 AM
Scott Will's Avatar
Yes, I know the reinforcements should (have) to be installed. Just wanna know if the bends on the holes needs to be accomplished. I tried doing it and didn't get the technique down.
You just cut a slit and go little by little around the circumference?
Scott Will
http://will2fly.com
CFI - CFII - MEI
Old 07-25-2005, 09:07 AM
Yes, I used a block of Delrin about 3/8" wide and you will slit it about 5/16" deep and bend a little at a time and go round and round a few times carefully and you will create a smooth flange
www.JeffsRV-7A.com
N808TX
Old 07-28-2005, 05:38 AM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default pay attention to the size of the rivet holes
It is possible to get the flange going in the wrong direction if you miss that the center part has pre punched holes of two different sizes, which is the clue for how it fits to the frame and skin. Also, hardwood might work instead of delrin and may be easier to find. Even it the flange is an "outie", it will still be OK.
Old 08-23-2006, 02:13 PM
TX7A TX7A is online now
Is this an optional kit or is it part of the finish kit?
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 08-23-2006, 02:18 PM
Scott Will's Avatar
It's not mandatory... but it is included in the finish kits now. It does stiffen it up A LOT!
Scott Will
http://will2fly.com
CFI - CFII - MEI
Old 08-23-2006, 04:35 PM
Jim P's Avatar
Jim P Jim P is offline
Default Process for Tip-UP
I didn't see the answer to on or off the a/c, but I drilled the individual reenforcements to the frame while off the fuse. Then drill to the skin (aft edges) while on the fuselage. This should prevent any twist from getting into the assembly. Then again, there's enough weight on this that it's goign to flex anyway.
Jim
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 08-23-2006, 05:32 PM
kentb's Avatar
kentb kentb is offline
Wink delrin is easly found it you...
Originally Posted by hevansrv7a
Also, hardwood might work instead of delrin and may be easier to find..
Just stop by any place that sells kitchen cutting boards, get the white plastic one. I had fun with a $2.00 board cutting it into various tools and spacers.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
