Old 09-13-2017, 10:17 AM
mike3715 mike3715 is offline
Default Slider canopy bow crack
Just landed at work and found the following long, thin crack in the exterior canopy bow of my slider RV7. The plexiglass doesn't seen effected. Any thoughts on repair Thanks!
Mike
Album:https://photos.app.goo.gl/ilzGjgg2xSu3tixQ2
Old 09-13-2017, 10:25 AM
PerfTech's Avatar
PerfTech PerfTech is online now
Mike
...I have the same issue, only mine is four times as long. If anyone has a good solution that preferably doesn't involve any work, I am interested! ..
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 09-13-2017, 02:20 PM
Raymo's Avatar
Raymo Raymo is offline
Mine did this early for about the same distance. I taped off the parts and used a finger nail file to rough up the two surfaces. Then mixed some flox with resin and worked it under the glass.
Mine's not yet painted but it is holding well after 100+ hours of flying.
I tell every passenger not to touch the lip to avoid another issue.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 09-13-2017, 07:04 PM
Awesome, thanks!
I'm sadly not much of a builder...any recommendations on what specific resin and such to buy?
Mike
Old 09-13-2017, 07:24 PM
koupster's Avatar
koupster koupster is offline
Default Grab Handles
Before you fix it, you may want to install roll bar grab handles http://www.aircraftextras.com/Handles1.htm
Unless, of course, you look forward to fixing it again.
Cheers, David
RV-6A KBTF
Old 09-13-2017, 07:54 PM
ArVeeNiner's Avatar
ArVeeNiner ArVeeNiner is offline
I had a similar thing happen but have been putting it off. I'm planning on taping things up first to protect the windshield from epoxy but i'm sure an errant drop or two will get on it. Does anybody know if cured epoxy can easily be removed from Plexiglass?
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
First flight: 5/28/12, Memorial Day.
Phase I Complete: 8/18/12!
2019 donation: complete
Old 09-13-2017, 08:11 PM
If you tried to epoxy something to plexi, it would probably slide right off. But if you accidentally got a drop on the plexi, it would certainly stick like something from a Krazy Glue (tm) commercial.
I'd wax or mask the windshield. Messing one up is expensive in time and money.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-13-2017, 08:35 PM
Scott Hersha Scott Hersha is offline
Try G/Flex 655 thickened epoxy. It's from West Systems and is compatible with all of their epoxies. It will wet out cloth and can be combined with flox, micro-fibers, cloth layup,etc, if you think you need it. It is a structural adhesive and remains much more flexible than standard West System epoxy. I got mine at a local boat store, but you can order it at Walmart and have it delivered to your local store for free - or Amazon.
SH
RV-8
Cincinnati, OH/KHAO
Old 09-14-2017, 08:36 AM
Raymo's Avatar
Awesome, thanks!
Mike
West Systems is widely used for aircraft construction and was likely used when that strip was bonded to the windshield. There are variations in hardener for fast (205) or slow (206) cure. Either should work fine for that small job.
I have people grab the center post for help getting out. No handles installed.
Ray
NSDQ
Old 09-14-2017, 10:51 AM
bret's Avatar
bret bret is offline
Is the fairing coming loose from the windshield? I did several test with epoxy to plexi and could not get a good bond no mater how I prepped the plexi, ended up laying up the fairing on packing tape, removed and sanded to shape and then Sika flex to bond it in place.
2019 gladly supported
