Old 07-21-2019, 01:21 PM
Brdog42 Brdog42 is online now
Default Anyone putting the new nose gear on a -6A?
Yes, no?
Iím rebuilding an -6A which had an engine failure while in the pattern 15+ years ago. 250 TTAF. Jim, the owner/pilot, my IA & former co-worker, was able to land on the runway. The only damage was a seized IO-360 angle valve the original builder installed. Jim was the second owner. The airframe sat in the back corner of Jimís hangar until last August. He also had a new IO-360 parallel valve in a crate and a new engine mount/nose gear. The original engine needed a different mount.
So, now Iíve this -6A in my hangar with that crate IO-360 & engine mount. Jim passed it on to me. :-) Iíve hung the engine and added baffling. But nothing else... no fuel lines, throttle/mixture cable, etc. Itíd be the time to add the new nose gear.
Iíve basically a super quick build kit with an Airworthiness Certificate. A clean slate. The interior is completely removed. No instrument panel. Iím still not sure where Iím going with it. Mostly day VFR sightseeing trips for friends around AZ. I fly IFR at work and donít feel the need to fly IFR in the -6A. Not with the IMC conditions we get in AZ, anyway. The -6A will be better with our DAís than the A150L. Although I miss that Cessna.
Tim
Tim
1973 A150L sold
RV-6A restoration in progress
KCHD AZ
Old 07-25-2019, 03:40 PM
Bruce Russell Bruce Russell is offline
Van's brought a fuselage with the new nose gear setup to Oshkosh. It's almost identical to the one on my RV-14A. I'm not 100% sure but it looks like you have to get a new engine mount also.
Bruce Russell
Clayton, GA
Simultaneous Repeat Offender
Old 08-14-2019, 07:15 AM
3KiloMike 3KiloMike is offline
Default 6A. Nose gear
Replace it! Never thought mine would give way, did all inspections, babied it on touch down, and seldom landed on grass strips. Still failed with 1500+ hrs on it.
New gear gets matched to old one and no engine mount replacement unless it was busted on prop strike incident.
Excellent investment!
Old 08-14-2019, 10:56 AM
johnbright's Avatar
johnbright johnbright is offline
Default RV-10 / RV-14A inspired nose gear
The nose gear new in 2019 does require a new motor mount.
Ref https://www.vansaircraft.com/wp-cont...stribution.pdf
http://www.vansairforce.com/communit...d.php?t=172564
John Bright, RV-6A 25088, at FWF
O-360, 8.5:1, vert sump, SDSEFI EM-5
Z-14 adapted for EFI
Newport News, Va
