I'm sure this is a rank newbie question, but I'm a rank newbie. Cost, weight, & "that's the way it's always been done" aside, what is the disadvantage of considering pulled rivets at least in the hardest areas to reach on the training edge of the lower wing skins? In flight there is no negative pressure that might try and pull them out, a touch of body filler would seal the hole, and it seems it would be a lot more consistent for a good rivet than having to use a bucking bar blind/by touch. Thanks for your patience; and the info.
