I'm a bit frustrated, actually a lot frustrated, trying to bend the vent lines. It looks like from the plans and other build sites that the spacer washers are used on one each side of the skin. In actuality, it seems like both used on the inboard side of the skin would be better to give the vent line a more straight run to that fitting.(not considering structural support of course) So instead, I'm trying to create a little tiny joggle just past the longeron and after making the s-turn to clear the rudder cable. All without bending the tubing too much. Otherwise once clear of the longeron, the tube would be hitting the fitting at too much of an angle.
Any words of wisdom from the group?
Thanks.
Thanks.
