Old 10-03-2019, 11:17 AM
olyolson's Avatar
olyolson olyolson is offline
Default Electroair MAP sensor
For those of you with the Electroair ignition on one side how did you penetrate the firewall with the vacuum line to the manifold pressure sensor on the cockpit side of the firewall?
RV-8, Flying
Previous airplanes: Corby Starlet, Citabria, Cessna 140, Vari-Viggen, RV-3, RV-4
RV grin every flight
"Sure is nice to have smart friends"
2018 dues paid
Old 10-03-2019, 12:21 PM
FasGlas's Avatar
FasGlas FasGlas is online now
My two MAP sensors are mounted on the firewall, engine side. Never had a problem.
Beech D17S Staggerwing
Lancair 360
Cessna 120
A&P IA
Old 10-03-2019, 12:28 PM
olyolson's Avatar
Default Map Sensor
Electroair recommended running a separate case ground in addition to the electrical ground wire in the 3 wire MAP sensor wiring connector. Did you do this as well?
RV-8, Flying
2018 dues paid
Old 10-03-2019, 01:36 PM
FasGlas's Avatar
The firewall is stainless and grounded to the engine, so it is case grounded. This is recommended to shield any EMI.
Lancair 360
Cessna 120
A&P IA
Old 10-03-2019, 03:00 PM
N941WR's Avatar
N941WR N941WR is offline
I use an aluminum "AN807 ADAPTER HOSE TO TUBE" fitting.
Here's a link:
https://www.aircraftspruce.com/catal...ages/an807.php
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
