Old 11-24-2017, 07:37 PM
Vansconvert Vansconvert is offline
Default Rates of climb, 9 vs 14 vs 7
So the 7 is the king of climb. I get that. The 9 at 160 horse and the 14 at 210 horse are within 100 feet per minute of each other per Vans published figures; stating that is with a fixed pitch on the 9, and assuming a constant speed on the 14. Why is the rate of climb that close with 50 horsepower less and a fixed pitch at that?
RV-7A
IO-360 Hartzell CSP
Purchased
Old 11-24-2017, 08:01 PM
grubbat's Avatar
grubbat grubbat is offline
Default King of climb?
The -7 king of climb? Really?
I would have thought that the additional 3ft of wing would give the -9 the edge, all things considered. Guess you learn something everyday.
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Efficiency and Fun
Comanche 260 - Poor man's RV-10
Aerostar 600A - My Twin Toy
Old 11-24-2017, 08:05 PM
The two biggest factors are span loading and excess power. The -9 stacks up well on both counts.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-24-2017, 08:20 PM
2450 fpm advertised on the 7A with a 200 horse and constant speed. The 14 with 210 horse is at 1900, about the same as a 9 , fixed pitch, 160 horse. Those are the specs on Vans website.
RV-7A
IO-360 Hartzell CSP
Purchased
Old 11-24-2017, 08:24 PM
Also consider the weights of the three and estimate the power to weight ratio and the excess power available at Vy.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-24-2017, 08:42 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
As for fixed pitch vs constant speed — you want the engine to give max power which usually means max RPM. You can get that with either a c/s or a fixed pitch. But the you need to convert that power to thrust, and there’s a zillion factors, including prop diameter. There’s also helix angle as a major factor (sorry, go look it up.)
As in so many other things, it depends.
RV-9A at KSAV (Savannah, GA; dual experimental touch screens with autopilot, IFR GPS)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2019 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 11-25-2017, 07:37 AM
Hartstoc's Avatar
Hartstoc Hartstoc is offline
Default Thinking apples to apples-
The 9 and the 7 share everything except the wing, so a meaningful comparison could be made with identically equipped airplanes carrying identical loads. I’m betting the 9 would decisivly outclimb the 7 in that contest, with the 9’s advantage increasing with altitude.
That said, I chose the 7 because it has so many more “hot-rodding” and maneuvering options. I love the thrill of a composite Hartzell pulling 190 HP at max ROC and I love boring odd-shaped holes in the sky, but I also have deep respect the wing John Ronce designed for the 9 and the efficiency and economy it imparts to Van’s airplane.
Otis Holt-
RV-7A (bought)
Built Monnett Moni
Frmr Test Pilot/Author CAFE APR's:
RV-8A, S-7C, Europa, Glastar.
-2019 VAF donation!!-
"RV-Fun is inversely proportional to RV-Weight!"
Old 11-25-2017, 08:07 AM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Well there is the rudder, the elevator, oh yes, and the flaps. All very different too. Quite a few important differences actually.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 11-25-2017, 08:26 AM
Not meaningful to climb rate, which is the discussion topic.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-25-2017, 08:28 AM
Hartstoc's Avatar
Default I believe rudder and elevator are same 9 and 7, no?
And flaps are definitely part of the wing, but not used during such climb comparisons. Minor differences in empannage would have little influence on climb in any event. Differences in power, prop, and weight are what need to be controlled to make a meaningful comparison.
Otis Holt-
RV-7A (bought)
Built Monnett Moni
