William Slaughter
First of all, I have already made the "big cut", which so far has turned out to be the quickest and easiest part of the whole deal. My problem is that my canopy seems to not be very "deep". When removing the flange at the beginning, I took pains to not remove any height that I might later need, and yet I'm struggling to get the canopy low enough on the frame to achieve the "stock" edge distance in the central area (about even with the mid-cabin brace), much less get some extra depth to allow the Danny King soft "bushing" procedure. I have about a 5/8" range fore and aft where the canopy fit is pretty good overall, and made the big cut such that the canopy will still sit on the front hoop either way. Due to the slope of the canopy at both ends, if I slide the canopy forward, the forward edge drops down, but the aft rises up, and vice-versa, leaving me with no net improvement in the middle. At this point, I can only envision two possible remedies. One is to "cheat" the canopy bow at the rear down below the 5/8" minimum specified clearance to the canopy rail, but to what new minimum? The other is to cut off the "tail" of the canopy which is resting on the bow at the rear, thus allowing the aft portion of the canopy to incrementally slide down over the bow, and just modifying the skirt as needed to cover it up. Or both. I'm more than a bit concerned about "gotchas" I'll have later down the road with either solution. Any help would be very much appreciated. Thanks.
