  #51
Old 03-23-2018, 07:41 AM
MED MED is offline
Thanks, Eric, I know. To get the axle mounting holes for the wheel pants horizontal, I had to swap sides from the way the factory had the caliper set up. Fortunately, as you point out, the bleed screws can be reversed.
MED
140236
N435MD reserved
Old 03-23-2018, 09:52 PM
didja didja is offline
Default RV-14a empannage status
Currently finishing up empennage kit! Started Nov 1st of 17 and should be done by the end of april!
Scott Emerson
RV-14a Kit# 140432
Working on: Wings
Construction log: https://www.youtube.com/channel/UCaZ...Uv2rlQsHtdRmmg
Donation Paid (military)
Old 03-24-2018, 02:02 AM
control control is offline
Not sure if it is possible to share pics from FB to others than your FB friends...
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 03-24-2018, 08:15 PM
kiljoy's Avatar
kiljoy kiljoy is offline
Default Can't put this piece on a shelf
I'm deep into the tailcone. This is a fun chapter. Thank you Van's for the excellently prepared wiring harnesses!
Dues paid (2019)
RV-14 #140394
Empennage - done(ish)
Wings - done(ish)
Fuselage - Crating late Jan. 2019
YouTube Build Channel
Old 03-25-2018, 07:52 AM
Erimo's Avatar
Erimo Erimo is offline
I know, I had the same situation
Otherwise, what fitting did you install on the bottom of the fuselage to connect to upper end of brake hose ?
The AN816-2D don't match with the fairings. So I'll order AN823-2D. They'll fit better the gear legs.
Eric
RV 14A - #140252 - Flying
France
2018 dues paid
Old 03-25-2018, 05:04 PM
MED MED is offline
I had planned to use AN816-3D, but I haven't installed them, yet. Thanks for the tip about the AN823-2D. I'll see what fits best.
MED
140236
N435MD reserved
Old 03-26-2018, 06:53 AM
Erimo's Avatar
You are right, it seems to be 3D.
The straight fitting and hose interfere with fairings. i think an angle fitting is better.
Eric
France
2018 dues paid
Old 03-26-2018, 09:57 PM
still trying to figure out how to post pics so that its not a link! Computer genius, or even literate, I am not! lol!
Scott Emerson
RV-14a Kit# 140432
Working on: Wings
Old 03-27-2018, 06:55 AM
MED MED is offline
Try tinypic.
MED
140236
N435MD reserved
Old 03-28-2018, 02:47 PM
MED MED is offline
Default RV-14A Engine On
MED
140236
N435MD reserved
