Old 06-30-2012, 04:02 PM
edward7048 edward7048 is offline
Default weight and balance
the manual said to put 2 inch blocks under the main wheels to level
the aircraft. My aircraft is level when on the main gear. I wonder if this
is normal?
Old 06-30-2012, 05:31 PM
MartySantic's Avatar
MartySantic MartySantic is offline
Why do you believe it is level without the 2" blocks. What is your reference?
Marty Santic ----- W9EAA
RV-12 N128MS ----- Now Flying
My RV-12 Build Log - http://www.martysrv12.blogspot.com/
Davenport, IA
Old 06-30-2012, 06:56 PM
with the canopy open I amchecking for level at the longeron as in the
manual.
Old 06-30-2012, 07:58 PM
sf3543 sf3543 is offline
Default If its level, then its level!
You could also let air out of the nose wheel to get the nose down.
Don't forget to close the canopy to get the correct weight on the scales.
Steve Formhals
RV6, RV8 (2), RV12 & RV3
A&P, Tech Counselor & Flight Advisor
Old 06-30-2012, 07:59 PM
morsesc morsesc is offline
This was confusing. We assumed that you put 2" blocks under the mains when you place the nose wheel on the scale to make level. If using 3 scales, no need.
Old 07-01-2012, 01:26 AM
crashley crashley is offline
Default balance
I believe 2 " blocks under the mains brings it up to level if using 3 scales blocks still needed
Old 07-01-2012, 08:59 AM
A fellow builder said he called Van's about this and was told that 2" blocks were used to raise the mains only if using a single scale for the nose wheel. After wheel pants, paint and carpet, my 12 is due for another wt and bal. Need to find out for sure.
Old 07-01-2012, 09:26 AM
Walt's Avatar
Walt Walt is offline
Every aircraft must have a leveling means to determine CG, if it's not in the manual somewhere than Van's needs to supply that info.
Walt Aronow, Dallas, TX (52F) RV7A, IO370, C/S, 1500+hrs
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 07-01-2012, 02:06 PM
Lines of communication must have gotten crossed somewhere, because the above is totally wrong. How would someone at Van's now how thick the scale being used was?
When computing the weight and balance of an aircraft based on weights obtained at the locations of each of the wheels, the airplane must be positioned at the same pitch attitude that was used by the manufacturer when they derived the C.G. range limits.
The RV-12 PAP specifies that the airplane be weighed in a level attitude when measured at the canopy side rails.
This can be done one wheel at a time, but it is usually not as accurate.
Regardless of how you choose to do it, the pitch attitude needs to be adjusted because the normal static pitch attitude with the airplane sitting on all 3 wheels is tail low. To get it level it requires the main wheels to be shimmed up about 2" (the reason it calls for the 2" blocks).
If you are weighing one wheel at a time, it would require 2" blocks under each main wheel, plus blocks equal to the scale height, under each wheel not on the scale.
Another method for leveling the airplane can be to remove air from the nose tire, but the reason the blocks are specified is that you need to make the nose tire almost completely flat to get the fuselage leveled at the cockpit side rails.
Which weighing method used does not matter, but the pitch attitude the airplane is in while doing so is critical if the final results are going to mean anything.
As already mentioned, remember to close the canopy after getting it leveled on the scales (it does make a difference).
Old 06-04-2018, 10:36 AM
AirHound AirHound is offline
Default Factor Wheel Pants on and off for W&B Calculations?
Unable to find VAF discussion on RV-12 Wheel Pants regarding W&B. Is the weight significant to recalculate whether they are on or off?
Doug
