Old 10-19-2018, 05:38 PM
Default Had an Excellent Flight this Morning…
I woke up at 6:30am and it was 30F outside with a heavy frost on the grass. I texted the hanger cell phone switch to turn on the engine preheater for 2-1/2 hours. When I got to the plane at 9am skies were sunny and no clouds. I powered the EMS and oil temp was 75F. I installed the largest of the three Van’s winterization covers for the oil cooler. I called the local AWOS and Density Altitude was -200 ft. Air was heavy so engine made more power and prop bit into the air really well causing the plane to accelerate fast on the take-off run. Initial climb rate was 1200 fpm with ¾ fuel and one person. 133 mph indicated cruise and 136 true at 2500MSL. Visibilty must have been 100 miles and air was smooth. Just love’n it….
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 475
LSRM-A Certificate 2016
MJ Stricker (Father & CFI) - 1st Lt. Captain B-17H
Old 10-19-2018, 06:17 PM
snopercod's Avatar
Life is good.
(2019 dues paid)
Old 10-19-2018, 08:05 PM
20 KT wind - breezy!
Old 10-19-2018, 09:57 PM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
Do you normally cruise at 5400 RPM?
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 435 Hrs on the Hobbs
Old 10-20-2018, 12:43 AM
All the time. Rotax is designed to run at top of green arc.
EAA #499867
