  #31
Old 10-12-2018, 06:46 PM
Mark33 Mark33 is offline
Default Fore and aft intake manifold.
Ross, What about designing an intake manifold/collective that runs fore and aft...similar to the Edge Performance setup? A single throttle body could be used with this type of intake and the individual intake runner lengths and angles could be adjusted to accommodate different airframes. You could also then ditch the stock cast manifolds. Edge may be a four letter word, but I’m just using their intake manifold design as and example and to give food for thought.
Old 10-12-2018, 06:55 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
There is no room for this type of manifold on the RV-12 installation without moving a lot of components already attached to the engine- coolant bottle, ignitors, hoses, cylinder air ducts etc. We offer a longitudinal one too but not suitable on an RV-12.
https://ixquick-proxy.com/do/spg/sho...b1abed6a5f1b69
https://ixquick-proxy.com/do/spg/sho...37020aa08de5dc
These two photos give you some idea of all the stuff mounted in the middle of the engine.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 428.6 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 10-13-2018, 10:26 AM
AJSWA AJSWA is offline
Ross,
Thanks for the charge upgrade options kinks.
The Flygas double alternator was another. @1.5 kg
www.flygas.info
Last time i enquired about the SH charge upgrade option, it was no longer available. Perhaps it's available again now?
Andrew
RV 120573
Old 10-13-2018, 11:11 AM
rv6ejguy's Avatar
Originally Posted by AJSWA View Post
Ross,
www.flygas.info
If not available, I wish they'd take down the page. I don't know. Someone told me about these a few years back and it seemed to work as advertised.
Old 10-20-2018, 01:24 AM
Ross,
A correction regarding the S/H F3030 - 500Watt charge system upgrade.
The system i made enquiries about January this year was the Silent Hektik V1410 525W rotor and stator
. The Silent Hektik V1410 option did not have the 2 ignition system charge coil windings to supply power to the ignition system, so it was not a direct replacement for the Ducatti 250Watt stator and rotor.
A battery powered ignition system was also required in conjunction with this option.
The current advert in the link you posted, is advertised as a 500 Watt direct replacement assembly for the ducatti 250 Watt system. (Joeri was good enough introduce me to google translate and pointed out Kürze wieder lieferbar = Available soon)
So, this is looking very much like an effective charge system upgrade with very the advantage of minimal weight and additional mechanical complications.
Andrew
RV 120573
Old 10-20-2018, 06:36 PM
Gagarin737's Avatar
Gagarin737 Gagarin737 is offline
I contacted Silent Hektik for some more info. Underneath their answer.
Aero 2019 will be from 10-13th of April 2019.
Regards, Joeri
Guten Morgen
and thanks for the email.
We want to fabricate the first 100pcs alternators before
spring 2019 and show it at the AERO_2019.
warm regards
PH-BZT
MyKitlog
Picasa pictures
Old 10-29-2018, 02:56 PM
Bad1996 Bad1996 is offline
Ross,
www.flygas.info
The verbiage on that site is painful to read. Almost written in Chinglish.
