Old 08-24-2018, 10:42 PM
Caseywhite Caseywhite is offline
Default Van's stabilator fairings
Right now I am in the process of completing the stabilator I installed the fiberglass fairings that are available through Van's. I noticed a small amount of waves in the skin of the stabilator skin where it overlaps the fiberglass. Has anyone else installed them and if so how smooth did the skin come out. I have looked for pictures on the web and none of them are close enough or high enough resolution to tell.
https://drive.google.com/file/d/1CAT...w?usp=drivesdk
Old 08-25-2018, 06:56 AM
AeroDog AeroDog is offline
Default Stabilator tips
Be sure to notch the fiberglass that slides in under the aluminum skin for all rivet heads. The manual says to do it, but the words didn't prepare me for the amount of notching that was required. You can see my pics here:
http://jerre-hill.blogspot.com
Jerre
Empennage, fuselage and wing kits complete
Finish kit nearly complete
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
=VAF= dues paid 2019
Old 08-25-2018, 07:34 AM
joedallas's Avatar
joedallas joedallas is offline
Default CS4-4 Rivets
These Photos show the Process for using CS4-4 Rivets
http://joesrv12.com/Builder%20Log/bl_12A_01.htm
Jerre
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 08-26-2018, 02:03 PM
Thanks for the input on the fairings. I am building my rv12 Elsa but the countersunk rivets look very nice.
Casey
Old 08-27-2018, 05:07 AM
Vdog20 Vdog20 is offline
I just installed my fairings a couple weeks ago. They look pretty much identicle to yours. I wasn't totally happy but figured the only person that's going to notice is me.
Old 11-11-2018, 08:26 PM
jpflys1 jpflys1 is offline
Having completed the HS SB I am moving on to stab fairing (Van’s).
I don’t understand so many notches- As I interpret the instructions, the fairing goes “inbound” over the rib; ie skin , rib the fairing. Of course except for the 10 rivets that are rib to skin& rib to rib.
Has anyone match drilled the fairing before they install the ribs ? This technique would seem to better limit enlarging skin holes.
