Old 10-17-2014, 04:46 PM
dbhill916 dbhill916 is offline
Default Control stick pushrodódoesn't fit
Hi all,
I'm looking for some words of wisdom with respect to trying to attach the pushrod assembly to the bottom of the control sticks, pg 32-05 step 6. After spending many fruitless hours trying to get my hands in there to line up the steel washers and the control rod bearing, I realized that it's not going to fit.
The internal width of the fork is 1/2", but the width of the steel washers plus the bearing is 9/16". Following the maxim of "if it doesn't look like it fits, then you're doing something wrong", I'm looking for some insight as to what I'm doing wrong.
Just for my own curiosity, what is the purpose of those steel washers? If they are to make a nice tight fit, then are both needed? Specifically, if I omit one of them, then I get a pretty good fit without needing to scrape my knuckles excessively.
Thanks in advance for any insights,
-dbh
David B. Hill
N76012
RV-12 #0760
http://n76012.blogspot.com
Dues paid through 6-2019
Old 10-17-2014, 05:49 PM
KiloWhiskey1's Avatar
KiloWhiskey1 KiloWhiskey1 is offline
You might double check that you have the correct rod-end bearing installed in the pushrod.
Keith Ward
Built two RV-7s (sold)
Partnership in an RV-8 (sold)
Old 10-17-2014, 07:56 PM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
Switch to thin washers?
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Nov 25, 2018
Old 10-18-2014, 04:51 AM
joedallas's Avatar
joedallas joedallas is offline
Default A different way
Take a look at this page step 06
http://www.joesrv12.com/Builder%20Log/bl_32_05.htm
They will install this way with a little thinking
This is a welded assembly
The washers are to keep the wings parallel ( wings of the welded assembly )
Sometimes you can change things vans requires in there instructions, however remember that a lot of engineering has gone into the design of their aircraft and in my opinion they have done a remarkable job. Make changes only if you have the ability to understand all things that the change will affect. Your best off to follow the plans to the T.
Originally Posted by dbhill916 View Post
Hi all,
-dbh
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Last edited by joedallas : 10-18-2014 at 05:51 AM. Reason: Sometimes you can change things ........
Old 10-18-2014, 06:53 AM
BigJohn BigJohn is online now
Your post dredged up an almost lost memory from five years ago. I had to "spring" the opening a tiny bit wider to make it go together. See picture here.
ďMaster PilotĒ Award, UFO Member.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
Old 10-18-2014, 08:01 AM
joedallas's Avatar
Default washers at the control rod bearing
John
I think he is talking about the washers at the control rod bearing
But it is the same type of thing as your post.
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 10-20-2014, 11:56 AM
RGLives RGLives is offline
Funny...I was just faced with the same step yesterday. Fortunately I didn't have any issues as you described. For what it's worth, I determined that the push rods could be attached to the control sticks off the aircraft and then could be snaked in place. I also used a rod from a hinge and stuck the washer on the end of the rod with a tiny bit of scotch tape. It worked quite well in setting the 2nd washer in place. It was tight but both washers fit in my case. Good luck!
Gary Livesey
Kit#12399
Old 10-31-2014, 04:59 AM
Unhappy fixed 1 thing, broke another
gents, thanks for the advice. I finally ended up taking the sticks out and attaching the pushrods, then unthreading the pushrod from the bearing and re-installed everything in place.
I now have a new problem: with the stick full back and full roll (either direction) the pushrod rubs against the AN365 lock nut on the forward control blocks. Has any one else had this problem? I'm waiting for some half-height nuts (AN364, IIRC) to see if that permits free travel, but I'd like to find out why they are rubbing in the first place.
Thanks again for any insights!
-dbh
David B. Hill
N76012
RV-12 #0760
Old 10-31-2014, 06:16 AM
rleffler's Avatar
rleffler rleffler is offline
David,
Without seeing what's on the other side, this suggestion may not work. What if you flip that bolt? Will it clear the head of the bolt? Is the room for the nut on the other side?
I'll see you on Monday.
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 10-31-2014, 09:45 AM
paul mosher
Posts: n/a
Are the flight control devices and the stops in place? The throw will be reduced with flight controls installed.
