Old 02-23-2014, 07:03 AM
TomVal's Avatar
TomVal TomVal is online now
Originally Posted by RVbySDI View Post
Just to give another point of reference to consider, I fabricated two gussets for mounting my magnetometers on the upper longeron (sp) behind the second bulkhead back from the baggage bulkhead. One on either side. It works great in that location. I used Velcro and brass screws to secure the magnetometers to the gusset.
Steve,
Timely input. I was planning to relocate my GRT magnetometer from the forward baggage compartment (poor location) to aft of the baggage compartment bulkhead. I like your location idea. I plan to take a closer look at location options when I open up the back to install the -12 fuel vent line.
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 02-23-2014, 07:25 AM
jsharkey's Avatar
jsharkey jsharkey is offline
Originally Posted by rzbill View Post
My GRT magnetometer is on the rear deck. Works fine.
One consideration though: The D-Sub mounting screws are a pain because they are up against the HS spar. You have to use a small stubby screwdriver (like a power screwdriver bit) which gets dropped into the fuselage....
If the HS spar would go ahead and crack and fall off, the D-Sub would be easier to install.
Magnetometer pic
I laced the connector to the box
Old 02-23-2014, 07:37 AM
Sam Buchanan's Avatar
Sam Buchanan Sam Buchanan is online now
been here awhile
Magnetometer pic
Yep, a zip tie or two will do a fine job of securing the connector without the hassle of screws. Matter of fact, my mag is secured to its mounting bracket with (non-ferrous) zip ties.
Sam Buchanan
RV-6
Fokker D.VII replica
