We are building a RV14A and looking at the finish kit it shows the hinge around the front hood / engine covers. And the QB fuselage kit came with half the hinges installed on the lips around the firewall and the clip in the upper middle of the firewall for holding /pulling the hinge pins
How do you get to it to pull the pins for the top cover facing the cockpit - though the oil access door?
If that is the case what is another system that would work better? I assume I would check the motor area in a pre flight check, at first all the time.
I did note that "E" used Sky Bolts. It there a better system? That would not take a tool to open?
Thanks, Larry
Thanks, Larry
