Old 08-01-2019, 04:45 PM
jcarne's Avatar
jcarne jcarne is offline
Originally Posted by kentlik View Post
Jereme,
You are going to go with the new mount? I talked to them, Vans, about it and there seems to be many changes to the stuff on the firewall and its locations for the new mount. Is this your understanding?
Great work by the way!
Well when I look at the pics it doesn't seem like too much will change. The only things I see maybe being an issue is the fuel supply fitting and the throttle cable. The big rubber isolator seems to be a couple inches away from the firewall. So, there is enough room to use 90 degree or maybe even a 45 degree fuel hose. The throttle cable may be an issue but time will tell, if that's the only thing I have to move I would be happy, although I still think there is enough room to snake it around the isolator. The only other thing in this area (center of firewall) is the cabin heat box and it looks like it will clear it no problem if you count the rivets on the firewall.
Originally Posted by RV7ForMe View Post
on the chance to sound like a broken record... you go man! you are going to be done soon and from the pics it really looks like a show plane in the making! keep it up and thanks for taking the time to share.
No problem and thanks for the kind words! Broken records sound good sometimes too.
I don't know about the showplane capability though. haha
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Fuselage almost done
Finish kit arrived
Exempt but gladly paying!
