RV-10 Flap Transition Speed
Kyle Boatright
I was flying in a friend's RV-10 over the weekend. The airplane doesn't have a flap position controller, so you have to hold the flap switch until the flaps are where you want them.
The thing I noticed was how long it took to fully raise or lower the flaps - probably 15 seconds each way.
Is that typical?
I've not measured the time to full deflection ... but before I had the VPX, I had to do the same. I had little tape tick marks on the leading edge of the flap for 15 degrees, which I could see over my shoulder. But I counted how long to get there, and it was a count of 7. I'd just count seconds instead of looking over my shoulder. So 15 for full deflection is probably accurate.
OK. That just seems like a long time a during configuration change when your hands are busy with trim, throttle, prop, etc.
I don’t find it to be an issue in the air, even on go arounds or missed approaches. However, I’m very picky about doing touch & goes. As a general rule I avoid them on runways less than 5000’.
I don?t find it to be an issue in the air, even on go arounds or missed approaches. However, I?m very picky about doing touch & goes. As a general rule I avoid them on runways less than 5000?.
I'm spoiled by the -6 with manual flaps. It takes a second or two to go from all to none or vice versa.
The -10 has a sizable pitch trim change between a full flaps 70 kias approach and a no-flaps 70 kias climb. The ‘slow’ flap change gives you a chance to keep up with the trim changes.
Edit: This is a serious enough issue that during the prototype development phase, Vans made an attempt to build an ‘auto-trim’ function into flap extension/retraction.
To be honest, I don't notice it at all, especially now with the VPX ... I just tap the switch, first notch, tap again, full flaps.
Even before, I just got used to counting to 7, never really seemed like an issue.
I never do smash and dashes ... always full stops, the others don't count in the tailwheel airplane, so I'm in the habit of full stops...
And as mentioned, on a go around it gives you time to retrim, etc.
Edit: This is a serious enough issue that during the prototype development phase, Vans made an attempt to build an ?auto-trim? function into flap extension/retraction.
Yep, but having my right hand on the flap switch for so long was uncomfortable (?) for me. Close to the ground, I really like a hand on the throttle. I have a flap positioning system for my -10, so it shouldn't be an issue for me, but that flap motor seemed to move slow, slow, slow...
