https://shop.vansaircraft.com/cgi-bin/shop.cgi?ident=1563724756-6-180&browse=misc&product=uhmwtape
Flyboys carried it also but couldn?t find it on their website.
Has anyone here used this? Is there a particular brand that is better?
Thanks!
I used it for my flaps. 14 years and counting. I put it on the underside of wing where the flap retracts rather than the flap itself so that if it yellows you won't see it. It will scuff the paint a little but not noticeably. And certainly won't show when the flaps are fully retracted.
An option, if you have silver or gray wings, is to use a stainless tape that is mentioned in posts elsewhere on this site. Search the Forums for it as people seem pretty happy with that.
Chris
Thanks. I will look into that.
Northwest Regional? Aero Valley? I'm in Denton, KDTO.
The uhmw tape sucks. It yellows and gets brittle over time. The good stuff is available from Flyboys or from PM Research. More expensive for a reason.
It should be applied to whatever surface you are trying to protect.
Erich
I think 3M Paint Protection Film is what you are looking for. Commonly used in the auto industry. Very easy to install. I have it anywhere on my aircraft where rubbing/scratching may occur such as a 2" strip around the firewall (easy to scratch the paint putting the cowling back on) leading edge of the HS, around the rear turtledeck and along the sides where the canopy could rub, lower fuselage where gear leg fairings rub on the fuselage/cowling etc...
Tom.
Slider
Blake is at Osh this week.
He has 3M paint protection film that works very well, lasts for years, doesn't yellow, and is easily removed.
https://www.flyboyaccessories.com/Paint-Protection-Film-p/2301.htm
