Folks,
Two questions from a first-time builder:
On page 18-06, step 6 the instruction is to install the bulkhead union and nut. The plans do not mention any type of sealant but the finger strainer and drain valves both call for Loctite or similar. I know the strainer and the drain both screw into fittings and the AN832-4D union just attached with a nut but...do I use Loctite, Proseal, chewing gum?
The two holes/fittings in the T-10003B ribs. I know the one at the bottom is the supply line but what is the one at the top for? Return line for fuel injection?
Thanks, James
Thanks, James
