Old 10-10-2019, 08:23 PM
engineerofsorts's Avatar
engineerofsorts engineerofsorts is offline
Default Well, I think I’m crying wolf
Looking at the fuel pump picture, the Assembly S/N is NOT on the cover we threw away—its on the base that the cover covers, so I should be able to see the serial number.
Rob Reese
RV-12 #120332 N73HR
Austin, TX
TangoFlight Mentor
Old 10-10-2019, 08:33 PM
Bob Y Bob Y is offline
When you get the chance to look at the pumps you’ll see both the main and aux pumps carry the same part and S/N as the assembly, leading me to believe the entire assembly is the only way one can get them. I’d be happy if someone could prove that assumption wrong as it will be a more economical solution.
Bob Y - builder 12iS
N569TT first flight 2/9/2020
Old 10-11-2019, 07:33 AM
rolick22's Avatar
rolick22 rolick22 is offline
Hope this photo helps a bit for builders that are not sure where the S/N are and what they look like. These are mine before install. Lucky for me my S/N are not in the I'm screwed range.
___________
David Rohrlick
PPSEL, A&P
RV-12iS Completed
Airworthiness signed off by the FAA 1/23/2020
First Flight on 3/14/2020
Phase I Finished on 5/7/2020
Need:
Paint?
Serial#12-0864
N112DR
VAF donation made for 2020
Old 10-12-2019, 09:28 AM
Flynfrfun Flynfrfun is offline
Default Curious
...if all those connections need to be changed out with the rest of the rubber at 5yr intervals?
Old 10-13-2019, 09:03 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
This looks like a real dog's breakfast. That's the best Rotax could do?
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 439.3 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 03-23-2020, 11:28 AM
todehnal todehnal is offline
[quote=RV12JT;1379096]I was on the fence ordering my Sling 2, as to which engine I wanted. TAF convinced me that maybe I’d want the 912 ULS, at the time, rather than the iS. All due to the VIRB ration issues the iS was still exhibiting. So far, I’ve only had one recent SB, for carb circlip replacement, less than an hour job. On the other hand, the iS motors have had several SB,s, especially the 915i#.[/QUOTEt]ake the
Hey John, did you remove the carb to replace the circlip?? I was just looking at my engine and it looks like it would be an easy job if you could just take off the chamber top to access the needle to replace the clip, instead of having to remove the carbs first. Or, am I missing something.
Thanks..............Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 03-23-2020, 01:06 PM
[quote=todehnal;1416731]
Neither carb must be removed from the engine for circlip replacement. Simply remove top cap and slide. Use high-grade slotted screw driver that fits central screw retainer. If thread Loctite doesn't loosen use heat iron on top of screw. Heat loosens Loctite...
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 562
LSRM-A Certificate 2016 for RV-12 N633CM
Old 03-23-2020, 05:38 PM
[quote=Piper J3;1416771]
Do you need to resynch both carburetors after performing this update?
Old 03-23-2020, 05:44 PM
RV12JT RV12JT is online now
Hi Tom, no removal, just what a piper J3 said. I had Midwest Sky Sports do mine. We found both original CirClips loose, one worse than the other. No carb sync either.
Old 03-23-2020, 06:11 PM
[quote=RV12JT;1416848]
The circlip is not really loose – it is pinched by the screw in the slide from above. The main needle is designed to float which gives the appearance that the circlip is loose. The needle needs to float so it centers itself in the main jet and doesn’t rub on the jet which would cause wear and allow a rich mixture. It’s interesting… the needle centers itself with the ~5 GPH flow of gasoline coming vertically up thru the main jet.
EAA #499867
