Old 10-14-2019, 09:05 PM
Scott Hersha Scott Hersha is offline
Disc sander for making things flat and taking material off, scotch brite wheel for deburring/polishing. My scotch-brite grinder (Chinese-made), pedestal mounted, has been in operation for almost 20 years (5 airplanes), still running strong - not with the same wheel of course. My grinder, like most, is dual wheel and I have a different grit wheel on each side.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 10-16-2019, 07:01 PM
ringlasergyrosandwich's Avatar
ringlasergyrosandwich ringlasergyrosandwich is offline
Originally Posted by mturnerb View Post
I like the buffer from Harbor Freight for Scotchbrite wheels - the spindles are longer, and no guards to get in the way. Much easier to to maneuver longer pieces while deburring/shaping. I also used their stand to mount it - again better than bench mounting as stand can be moved into position to maneuver long pieces. I shamelessly stole the idea from Synergy Air when I did their class.
Buffer: https://www.harborfreight.com/power-...fer-61557.html
Stand: https://www.harborfreight.com/univer...tand-3184.html
How did you mount the buffer? I'm trying this setup but the holes don't line up.
Old 10-16-2019, 07:44 PM
mturnerb mturnerb is online now
Ahhh - good question. I just drilled holes to match the buffer in the stand. Had kinda forgotten! Also - I think the wheels came with adapters to fit the size of the buffer spindles.
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
Old 10-17-2019, 11:14 AM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by Bruinpilot View Post
I did put the wheel in my drill press. I love it there. Very accessible. Is the slowest speed ok? The grinder spins much faster... great idea though.
Try the faster speeds, if you need.
I still use the slowest speed, when working on a new project.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
