Old 09-19-2017, 01:04 AM
RicoB RicoB is offline
Lightbulb Where to buy a P-mag
I have called e-magair twice and left messages. Never heard back..
where can I buy them? (the complete setup, gear, spark plug adapters , wires)
Thanks!
Rico Burgos
RV9a - Building, Based at KWHP (CA)
C-150 Based at KMOD
VAF Paid 2018
Old 09-19-2017, 04:54 AM
N520TX's Avatar
N520TX N520TX is offline
Default Aircraft Spruce
http://www.aircraftspruce.com/catego...tion_emag.html
All the pieces can be purchased here.
Ron Walker - 40XS
RV7a - Flying
RV10 - Flying !
FFI Flight Lead - www.FalconFlight.aero
Old 09-19-2017, 06:05 AM
Brantel's Avatar
Brantel Brantel is offline
If you need a gear you can get a huge discount if you purchase it direct thru Emagair when you bundle it with the PMag. They have some sort of special deal with Lycoming to be able to do this.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 09-19-2017, 06:39 AM
I am trying to buy from them. But I guess it has to be via phone call and I have called twice! No luck getting someone to return my call
Rico Burgos
C-150 Based at KMOD
VAF Paid 2018
Old 09-19-2017, 06:50 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default Keep calling
If you want to buy from Emag......keep calling and leaving voice mails.
They will answer eventually.
I had the same issue around Oshkosh....while trying to order.
Once you get someone on the phone they are very helpful.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 09-19-2017, 08:11 AM
maus92 maus92 is offline
Yea I'm still awaiting an answer to an email I sent last week - I wonder if they / their employees were affected by the hurricane?
CA
2000 RV-8A | O-360, FP, G3X Touch, VP-X, EarthX
Eastern Shore | KESN
Old 09-19-2017, 08:28 AM
jpowell13 jpowell13 is offline
Default Don't forget the clamps
If you are replacing a Bendix mag, don't forget to order the two clamps that hold the Pmag to the assessory case. I think they are included in the "install kit" from Emagair. I just installed a Pmag before going on a x-country and had to get those clamps over-nighted when I realized they didn't come with the mag.
If you're replacing a Slick mag I'm told you can use the same clamps used with the Slick.
I ordered from Spruce and all was good except for the clamps. I had a problem getting my timing set right because I had inadvertently positioned my flywheel at the wrong angle when changing my alternator belt. People at Emagair were helpful; even on a Saturday, in getting me going.
John
Old 09-19-2017, 09:06 AM
Bob Martin's Avatar
Default waiting
You might be waiting a long time for a email response.
I emailed them a virtual order and never got a response, but did get emailed info on the shipping and receipt, etc. So they do use it.
Bob Martin
Old 09-19-2017, 06:04 PM
Exclamation
I am still confused on which mag to replace. i thought i decided to keep my impulse coupler one but than when i spoke with someone from Emag he suggested to repalce the impulse coupler one with the Pmag. I am on top of the wall and don't know which side to jump. both ways have pros and cons!
Heeeelp.
Rico Burgos
C-150 Based at KMOD
VAF Paid 2018
Old 09-19-2017, 07:32 PM
scard's Avatar
scard scard is online now
Heeeelp.
Don't Jump!!! Take the ladder back down to the logic side. Each rung is one to be carefully considered on one's own. Only you can own it.
Scott Card
RV-9A N4822C flying 1900+hrs. / Cedar Park, TX
Track
