Old 09-06-2017, 12:33 PM
Jesse's Avatar
Jesse Jesse is offline
Default Lose 2 Cylinders at Idle
I have a plane here with a Lycoming O-360 that has been down for a panel upgrade. When we start the engine, Cylinders 1 & 4 drop out at Idle. At power (pretty much anything over 1,000RPM) the EGT's and CHT's come up, but at idle, they drop back out. It flew fine and made good power. The engine has 2-300 hours.
We checked for stuck valves and they are fine, not stuck or even a little sticky.
We can test new plugs, but the chance of having both plugs on two different cylinders dropping out the same is very low.
We have looked for intake leaks, and haven't completely ruled that out, but everything looks great on those cylinders.
Leaning out at idle doesn't change anything, but the RPM does increase significantly.
Any other thoughts, things to try?
352-427-0285
jesse@saintaviation.com
Old 09-06-2017, 12:37 PM
Raymo's Avatar
Raymo Raymo is offline
My engine did the same on one cylinder. The flow divider had piece of junk in it, causing the idle fuel flow to be restricted. At higher fuel flow/RPM, the plunger inside raises the internal valve, allowing normal fuel flow.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 09-06-2017, 12:46 PM
mahlon_r mahlon_r is offline
Missing intake port pipe plugs, leaking primer, leaking stand by vac system, really has intake leak written all over it :-)
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 09-06-2017, 12:50 PM
Jesse's Avatar
Not fuel injected, so I think we can rule that out.
352-427-0285
Old 09-06-2017, 12:51 PM
Jesse's Avatar
Good Luck,
Mahlon
That's exactly what I have been thinking. We'll check all of those things. Thanks!
352-427-0285
Old 09-06-2017, 01:07 PM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default Basics
Jesse,
I am by no means a engine guy....
But basics
Air fuel spark.
Air would just be intake spider....and gaskets. Leaks cause poor running engine, especially when idling because the ratio of leak to combustion air is high. if all looks good, most likely not your smoking gun
Fuel...carb is carb...and if spider is ok, then fuel should be ok as well.
Ignition: assuming mags and aviation plugs, you did not say age/condition etc. Two mags wired normally would have a mix of wires from both mags so both mags failing is improbable. Plugs could be bad on those two cylinders and an easy thing to check/clean/test/ohm.
Primer---is the primer only on 1 and 4?
Good Luck
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 09-06-2017, 01:22 PM
ty1295 ty1295 is offline
Leak Down test?
I am a firm believer in them, much better than compression. I spent a couple years on a top fuel motorcycle race team, and one of the first things we did after every run was a leak down test. We would know instantly how much work we would be needing to do to be ready for the next round and where the issue was if it was mechanical.
Jeff Scott
Proud to have flown with P. Wagstaff and some odd Russian.
RV9A #91247/#91434
Old 09-06-2017, 01:31 PM
I had an O-360 lose one of the pipe plugs in a primer port on the way to OSH about 15 years ago. Was running fine until I pulled power to descend for a fuel stop, then ran horribly. Bringing power back up, ran fine.
Now, losing two, at the same time.....
Old 09-06-2017, 02:39 PM
Jesse's Avatar
We found the problem we are pretty sure. Just about to run a test.
This is what happened. The primer (electric) was sticking and staying on. The primer goes to cylinders 1, 2 and 4. Cylinder 3 has the manifold pressure pickup in the primer port. It turns out that cylinder 2 had a leaky primer fitting, so just cylinders 1 and 4 were getting full time primer, which must have just made them run rich at high power, but so rich at idle that they stopped firing at all (or were firing but the EGT's were just hugely low because they were hugely rich. Kind of the opposite problem as we were thinking, but similar symptoms. We fixed the sticky primer and fixed the leaky primer line into cylinder 2 and are about to test.
Thanks for the ideas, guys.
352-427-0285
Old 09-06-2017, 05:10 PM
JonJay's Avatar
JonJay JonJay is offline
Jesse - you have a lot of experience, yet you still put things out there when you find issues. That really helps all of us learn. Thanks for posting.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
