Old 11-15-2018, 01:39 PM
lr172 lr172 is offline
Originally Posted by az_gila View Post
Yes, but surely this will seal...
I would expect so. However, the manufacturer recommends a minimum or optimum amount of compression for a reason (can't recall the exact percentage), so I wouldn't simply trust the fact that it "looks like it will seal."
N64LR
RV-10 in progress
Old 11-15-2018, 02:18 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Good point on data....
First one I found was a Grainger identical part -
Although many mistakenly believe that a higher compression rate results in a stronger hold, our bulbs are designed and engineered to work best at 25-40% compression of its original height, with 25% being optimum. If you compress it more than that, its life and serviceability will be limited. When building your part, be sure to choose the bulb size that correlates to a 25% compression rate for your application.
https://vimeo.com/28068686
https://www.trimlok.com/rubber-extru...rim-seal/hatch
I can't seem to find a manufacture's detailed data sheet for the actual McMaster product.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-15-2018, 02:23 PM
Well I am unhappily a part of the "Mistakenly believe" crowd. I would guess our seals are pretty similar if using the same type if foam EPDM. However, the Grainger seals look more oval than round, which may impact the desired compression level, as the round seals need more compression to become oval.
N64LR
RV-10 in progress
Old 11-15-2018, 02:46 PM
az_gila's Avatar
Smile
The catalog pics show the bulb as being quite round, but I would like to see an actual spec. sheet or application note for the McMaster product.
https://www.trimlok.com/secure/conte...i+10132016.pdf
Gil Alexander
Old 11-15-2018, 04:42 PM
Bill Boyd's Avatar
FWIW, Gil, and as detailed in another thread, I was shocked to find the 1/4" gap I had created was not enough to allow the door to close with the 3/8" bulb seal. Pin engagement was not happening no matter how I pushed. I took the gap wider, to .30" and still was not able to close the door.
Rather than grind further, which no doubt would have eventually allowed the door to close, I replaced the 3/8" bulb seal with a 9/32" bulb - 3/16" channel width seal. Perfect. I only have to add thickness to the door edges in a few spots because the narrower channel grips well to the thinner doorway edges that are left after all that grinding I did.
I don't know yet how well it will seal at the compression that's occurring, but I guess if I hear wind noise I can go back to the 3/8" seal or, perhaps more easily, add thickness to the door inner surface to increase the bulb compression of the smaller seal I went with. At this point I'm just delighted my doors finally close with a seal in place - and that without undue torque on the handle.
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 11-15-2018, 06:29 PM
Drippy Drippy is offline
Default rear hinge gap
I don't know about the rest of you but living here in VT cabin heat can be an issue during winter. So I have spend at little bit of time looking for leaks. The biggest flow outflow of air for me is around the door seal near the rear door hinge. Because of the cut out required due to the hydraulic piston and hinge I am not getting a good seal with my Mcmastercard seal. I tried putting a piece of fiberglass across this area but interference with the piston resulted in me grinding/sanding a way a path for the piston and the recent cold spell has demonstrated yes I am still getting pretty good flow.
But I like the idea of putting the gasket on the door in that area. I am going to give it a try.
Thanks for the idea.
Mike
N95VT
RV10
~150hrs flying
Old 11-15-2018, 07:41 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
I ended up with around a 25% compression. The seal works fine with only that amount. I have been flying for 6 years and 900 hours and the seals still look new. You will never get the doors to close if you try to over compress the seal, I tried.....
[IMG][url=https://flic.kr/p/24S2E8J]
[IMG][url=https://flic.kr/p/24S2DWS]
Bill Peyton
RV-10 - 950 hrs
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
Old 11-15-2018, 09:01 PM
az_gila's Avatar
Question
Bill, did that work out to about a 5/16 inch gap?
Gil Alexander
Old 11-15-2018, 10:39 PM
The base below the bulb is about .075", so 25% compression of the 3/8 bulb should net a .360" gap.
The 9/32" bulb would net about .280." Given that I followed other advise and set my gap at 1/4" maybe I will swap the 3/8 bulb for the 9/32 variety.
I am a bit concerned that my bulb came out of the package compressed a bit from round. if that is the norm, then we need a bit more compression to account for that.
N64LR
RV-10 in progress
Old 11-15-2018, 11:07 PM
az_gila's Avatar
Smile
Since I'm still sanding and making dust so I can use the just under 5/16 dimension. I have the very lumpy green cabin cover so keeping the 1/4 edge thickness is going to take quite a bit of work anyway.
With your numbers, a 40% compression of the 3/8 bulb gives a 0.300 gap, just under the 0.3125 (aka 5/16) guess I made.
I think I'll simply aim for a 0.300 gap with my existing seal.
Gil Alexander
