Old 10-24-2018, 08:46 AM
Default +1
Originally Posted by TShort View Post
I bought one of these after much research:
https://labelworks.epson.com/product/lw-px900/
Pricey, but very worth it. Every wire in the upgraded system is labeled with heat shrink tube. It is very easy to do, easy to read and makes things more serviceable down the road.
Plus you can use the labeler for all kinds of other things around the house and hangar!
+1 for this label maker.
Also, check out Hawk Labeling. They are AWESOME to work with!
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 10-24-2018, 09:03 AM
DRMA DRMA is offline
I first tried printing wire numbers on paper labels with my laser printer, cutting them into small strips, sticking them on the wire and covering them with clear heat shrink tube. This worked but took a lot of time and didn't allow for easy changes when I didn't have the right pre-printed label. So I tried just hand writing on the paper label, cutting and applying with clear heat shrink over the top. This worked, but also took extra time and didn't look as good. Both methods were too fiddly for my liking - just a personal thing.
I ended up purchasing a Dymo Rhino 4200 label maker with black on yellow heat shrink label cartridges in 1/4" and 3/8" sizes. The 1/4" works for most single wires, and the 3/8" fits the 2 and 3 conductor shielded cables. I selected the black on yellow color as the yellow labels are easily spotted on the white wires in a large bundle.
These tubes start out flat, so when you open the tube and put it on the wire, it will hold in place until you shrink it. This allows me to leave the labels on the wires after pulling them, and then to put them into final position and shrink them after trimming the wire to final length for termination.
While this is a more expensive solution than the paper labels with clear heat shrink over the top, it takes me less time, is more flexible, and results in a professional installation. So after all the money I've spent on the RV-10 and high priced avionics, the additional few dollars for this solution is well worth the money to me.
As for just color coding the wires, while I am using some color coded single wires, good luck finding multi-conductor cables in anything other than white. And these are mostly what you use for the avionics wiring.
While it is very important to have a well documented set of wiring diagrams, they don't provide as much help if you can't easily identify the wires when you are trouble shooting or have problems. As a professional electrical engineer with 40 years of experience in industrial instrumentation and control, I would never consider nor accept an installation where the wiring did not include a logical system of wire numbering with the wires clearly identified with their respective number at each termination.
Just my 2 cents worth. As the builder of an experimental aircraft, we are all entitled to our own opinions and to build as we see fit. That's one of the privileges of our experimental hobby.
Regards,
Dave Macdonald
RV-10 Finishing Kit & FWF in-progress
2019 VAF Dues Paid
Old 10-24-2018, 09:28 AM
Raymo's Avatar
Raymo Raymo is offline
The Brady BMP21 is a great unit for wire labeling. There are options for heat-shrink labels, as well, but I just use the 3/4" black on white and wrap the label around the wire.
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines
Old 10-24-2018, 09:34 AM
Default interesting
I had the opportunity to crawl around in a B-767-300-ER that was in for heavy maintenance recently.
The comment here's reminded me of some of the things I saw "behind the curtain". As most of the baggage compartment walls were removed, the wiring was plainly visible...literally thousands of plain white wires, hundreds of bundles, and running everywhere.
Even WITH the detailed schematics that I know they have, I would hate to have to troubleshoot a wiring problem in that jungle!
Bob
290 HP Barrett Hung
Wiring...
Old 10-24-2018, 09:54 AM
gyoung's Avatar
gyoung gyoung is offline
The big boys mark their wires the whole length. If you looked close you would probably find wire numbers stamped/etched every foot or so. Back in the 70's the avionics shop at TI had a wire stamping machine used to mark wires going into modification kits. I got a FWF engine package for my Navion that came off an Beech A36 and all the sensor wires were marked full length per their wiring diagram. And I just saw that ACS will sell you wire marked to your spec - really pricey but available.
Greg
1950 Navion - flying
RV-6 - 17 yrs and 99.1% done
1940 Rearwin Cloudster project next
4 L-2 projects on deck
Old 10-24-2018, 10:21 AM
Default yeah
They probably were marked but it would still be a nightmare trying to find which wire you were looking for...
Bob
290 HP Barrett Hung
Wiring...
Old 10-24-2018, 10:49 AM
Squid Squid is offline
+1 for Dave Macdonald's reply. The Dymo labelmaker along with Industrial heat-shrink labels work for me. Believe I first saw this recommendation in a HomebuilderHelp youtube video.
- John Munroe
RV-7: Bought & Flying
RV-8: Under Construction (SB wings currently)
_________________________
John Munroe
Base: Winchester, VA (KOKV)
RV-8: SB Wings
RV-6: Bought & Flying
VAF Dues Paid 'thru 2020
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
This is one of the reasons for making neat wire bundles, without the sphaghetti criss-crossing of wires that I see in many airplanes...so that once you *find* a wire (or identify it at one of the ends), you can easily trace it through the bundle.
2019 Dues paid!
Old 10-24-2018, 12:20 PM
Default yes
...but it the case of the 767, some of those bundles were as big around as a half dollar...
Anyone remember those half dollars?
Bob
290 HP Barrett Hung
Wiring...
Old 10-24-2018, 12:56 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
There's a whole 'nother part of documenting the wiring when it comes to avionics. Knowing what individual pins and wires are is nice, but it's also nice to know things at a higher level -- such as, serial port #1 from device A goes to serial port #3 on device D, that kind of thing. And similarly, all the input and output port settings on each device, all the autopilot gains, everything.
I documented all that in a spreadsheet, saved it as a pdf and have it on my cell phone. If I'm ever in the boonies with an avionics problem, they'll have the manuals with all the pinouts, but I'll be able to give them the as-installed sytem overview. There's a big difference...
And the avionics folks have standard color coding conventions. Better to use industry standards than invent your own.
Ed
RV-9A at KSAV (Savannah, GA; dual experimental touch screens with autopilot, IFR GPS)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2019 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
