After measuring compression we took a borescope and looked inside of all cylinders. Cylinder #3 has a mark at about 10 o'clock. We are puzzled what could cause it? Compression for the particular cylinder is 74/80 and the engine is nearing 3,000 hours of trouble free time. Take a look at the pictures below.
Looking at the piston. There are some swirls visible on top of the piston and against the most visible one there is a wear mark.
That's where the mark is located. About 10 o'clock if it matters.
Closer look at the wear mark.
What could be the cause? RocketBob are you around?
