Old 12-18-2009, 09:33 AM
murphyjr murphyjr is offline
Dayton ; I would like one. John Murphy , 1721 Horseshoe Ridge , Chesterfield , Mo. 63005 Thanks in advance
Old 12-18-2009, 10:17 AM
Frank Smidler Frank Smidler is offline
Default No issue with TOSTEN PTT
I have have two TOSTEN grips and love them. In 180 hours I have never accidently hit the PTT, yet it is comes naturally to hand when you are ready to talk. The chance of accidently hitting the PTT button has a lot to do with the design of the grip and how you normally hold the stick. If you just grab the grip your hand falls into the smallest diameter of the grip, just below the PTT. Normally you never have a "full grip" on the stick. It is more natural to have the arm resting on your leg and the thumb and two fingers gripping the base of the grip, well away from the PTT.
The TOSTEN grip also has a smaller red button just below the PTT. You can accidently hit this button. I use it for radio flip/flop and have accidently hit it twice (once on the first flight). I considered disabling this button, but once I become comfortable flying the plane with the afore mentioned 3 fingers, it has not been an issue.
Besides being a very comfortable and functional grip, they also look cool.
Frank Smidler
N96FS, RV-6, 2WI6
Flying 1/11/09
760 hr
Stoughton, WI
Formally of Lafayette, IN
Old 12-18-2009, 10:58 AM
tcone1's Avatar
tcone1 tcone1 is offline
[quote=AX-O;387521]I took a picture of Dayton's set up. I will have #1 COM on the trigger and #2 COM om the Throttle.
Ax,
If you do that, where are you going to put the smoke switch?
slick
Timothy Cone
Sierra Skypark (KE79) Fresno CA
RV-8, XP360, RV200
Flown Sept. 12, 2007
880 hours on the hobbs and loving it
Old 12-18-2009, 11:13 AM
mannanj's Avatar
mannanj mannanj is offline
Default Switch
Originally Posted by Dayton Murdock View Post
Hi All
I have a bag of those Red button switch’s if you send me your contact information I will mail you a switch for you deluxe throttle quadrant, there is an aluminum ring I make to adapt to the ¾” I.D. of the throttle handle to the switch that will be included.
Dayton:
Check your PM's. I need one.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 12-18-2009, 06:49 PM
AX-O's Avatar
AX-O AX-O is offline
[quote=tcone1;387750]
Ax,
slick
Activated via voice command. Readyyyyyyyyy, smoke ON!
Axel
RV-4 fastback thread and Pics
West Coast Ravens
VAF 2018 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weight out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk.
Old 12-19-2009, 02:00 AM
DakotaHawk's Avatar
DakotaHawk DakotaHawk is offline
Thanks for all of the replies - it's good to hear/see what others have done.
I made my first flight yesterday, and found that I really don't like the PTT on the trigger of my Infinity grip. It's just not "intuitive"! I'd rather have it on the top of the stick. But the top of my stick has a coolie hat for trim, an autopilot disconnect button, and a flap switch.
Well, I'll have to give this some thought...
Time to go fly some more!
_______________________________
Scott "Grumpy" Stewart
RV-7 N957RV (First Flight on Dec 18, 2009)
RV-14 N144P (Empennage complete, building wings)
#866 on the Van's RV-7 hobbs
#6563 on Van's generic hobbs
Arlington, WA
Old 12-19-2009, 07:34 AM
RV8R999 RV8R999 is offline
no relay required, so wiring is no different than any other configuration - the switch was designed to be a starter switch. Still had to drill a hole in the grip and route wires just like in the panel. The switch guard helps prevent accidental actuation.
Obviously a taildragger isn't difficult to start without a switch on the throttle. If however, you are holding the stick with your knees during the start sequence I think my point is made and is in fact the sole reason I put a switch on the throttle..because it makes it EASIER to start.
Old 12-21-2009, 08:59 PM
Dayton Murdock's Avatar
Dayton Murdock Dayton Murdock is offline
Default PTT switch
The guys that sent me a request for a switch are:
R. E. "Ernie" Butcher
Mannan Thomason
Dave Hyde
Bill Zaun
Buck Wyndham
If I missed some one please send me a P.M. with your adress
Dayton Murdock
VAF#408 RV4 N359DM Flying 940 hrs. 6/1/2017
Builder Log
Old 12-31-2009, 05:01 PM
mannanj's Avatar
Default PTT Switch
Mannan Thomason
Dave Hyde
Bill Zaun
Buck Wyndham
Got mine today Dayton. Looks great! Thanks!
I think I'll mill a short, narrow slot in the throttle lever where it goes through the top of the quadrant. That way I can epoxy the wires to the back side of the lever, go into the slot where they can't rub on the top fascia plate then back out to the back and epoxy the rest of the way down. That way there wont be any dangling wires to get ripped out when something catches on them.
See any problems with this idea
LAUS DEO
VAF788
Old 01-02-2010, 11:58 AM
nauga nauga is offline
Hi All
I have a bag of those Red button switch’s if you send me your contact information I will mail you a switch for you deluxe throttle quadrant...
I received my switch earlier this week and am just now getting my head above all of my family/holiday obligations. Thanks for the switch and your generousity.
Dave 'Nauga' Hyde
Nauga
2004 RV-4
