Old 01-12-2018, 07:12 PM
BillL BillL is offline
Default Valve stem adapter - any help??
I have looked but . . . .
OK, so the valve stem is very near the rim, and parallel to the axle. 5.00x5 wheel on the RV7. While is it probably best to remove the wheel pants, I want a way to access more often. So read on.
I am looking for a straight valve stem adapter that is open (not closed) type. I have searched via google and images to find one and surprised in not finding a small diameter open style. BTW - the open style has a rigid center that will open the Schrader valve, and allow two way airflow.
Here is a picture of a steel one with a threaded attachment. The final tool will have a rigid 6" tube terminated with this adapter so it can be pressed onto the stem through a hole in the wheel pants, read the pressure then add air with a valve connected to the air supply.
Does any one know where to find such an adapter?
Bill
Op Lims in hand 12-7-17
Prep for 1st flight underway.
2017 Dues Paid
Old 01-12-2018, 07:15 PM
I have a valve stem extension like this one for that purpose.
https://www.gemplers.com/product/HE3...180113011518:s
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 01-12-2018, 07:33 PM
shamer's Avatar
shamer shamer is offline
Default Valve stem inflation tool
Check out Cleaveland Aircraft Tools.
http://www.cleavelandtool.com/Cleave...uctinfo/VSI15/
Steve Hamer
RV-6
Eagle, ID
Old 01-12-2018, 08:30 PM
fl-mike's Avatar
fl-mike fl-mike is offline
I have similar, but stainless braided tube.
http://www.aircraftextras.com/Valve-ext.htm
Google "stainless braided tire valve extenders". Just be sure to get the kind where the inner "nut" is fixed to the hose and not free-spinning.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage started.
Old 01-12-2018, 09:12 PM
Larco Larco is offline
Not sure what you are looking for ? This?https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 01-12-2018, 09:16 PM
Kyle, Mike, thanks, but I was looking for a non threaded, direct acting tool.
This Cleaveland tool is just what I was looking for.
Thanks to all!!
edit: Thanks Larry, that one functions as desired (like my picture), but the Cleaveland one has is rigid and has a bourdon tube gage. I kinda like a gage better than the old style.
Bill
Bill
2017 Dues Paid
Old 01-12-2018, 10:11 PM
skybolt31 skybolt31 is offline
If you want to roll your own, this chuck is available from Graingers:
https://www.grainger.com/product/SPE...re-Chuck-1KUH2
Bruce Green
Eagle N110GM
Westfield, MA
