Old 01-12-2018, 04:54 PM
Default Rivet Cutter Recommendation?
My old unmarked rivet cutter is finally due for retirement. It's only 30+ years old. Can anyone recommend a quality replacement?
Old 01-12-2018, 05:30 PM
wirejock's Avatar
wirejock wirejock is offline
Default Rivet cutter
I have this one. Not the best but it works.
https://www.aircraft-tool.com/shop/detail.aspx?id=130
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 01-12-2018, 05:53 PM
ERushing's Avatar
ERushing ERushing is offline
David,
I've had really good luck in just using the side of the scotchbrite wheel to sand them down a little bit.
I take a piece of ~1/8" thick aluminum bar and drill/ ream #30. Insert a rivet. Hold a gloved finger over the back side of the rivet onto the bar (it can get a little hot if you take too much off at a time.) The aluminum bar holds the rivet nice and square and helps to position that rivet square to the scotchbrite wheel.
I have had less than stellar results with my rivet cutter....
Best Regards,
Eric Rushing
VS, Rudder, HS, Elevator, Tailcone - Complete
QB Wings - Complete.
QB Fuse - In Process. Tail & Fuse are one.
Molalla, OR
Old 01-12-2018, 06:50 PM
cajunwings cajunwings is offline
Not sure I would want to heat rivets up by grinding or any other means. Donít know if the strength or temper could be effected? Iíve used rivet cutters for years with acceptable results. Once in a great while a burr gets left behind and touch with a small file will remove it.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Old 01-12-2018, 06:51 PM
BillL BillL is offline
Originally Posted by ERushing View Post
David,
Best Regards,
+1
I have/use a USATCO 04-501 cutter, but many times do the above or on the belt sander to square the end. Maybe not needed, though, most cuts are pretty clean.
Bill
Op Lims in hand 12-7-17
Prep for 1st flight underway.
2017 Dues Paid
Old 01-12-2018, 07:26 PM
TShort TShort is offline
I've got this one:
http://www.yardstore.com/rivet-cutter.html
I've had good luck with stuff from the Yard store.
Thomas Short
KUMP - Indianapolis, IN
RV-10 N316JS bought / flying
RV-8 wings / fuse in progress ... still
N329TS (had it, lost it, looking for new number)
Old 01-12-2018, 08:37 PM
ColoCardinal's Avatar
ColoCardinal ColoCardinal is offline
Another vote for the Yard Store. Family owned and great service.
Carl - - Morrison, CO
N16CB will fly this year!
Paint booth built and in operation. final fitting of everything soon. Inspection in February?
paid 'til 10-18
Old 01-13-2018, 07:53 AM
jsharkey jsharkey is offline
I don't remember having to cut any rivets during my entire RV-6 slow-build and the rivet cutter that came with a starter tool kit has never been used. (Same with the pneumatic drill for that matter) The range of rivet lengths that came with the various kits in a multitude of little brown bags covered every eventuality with lots left over.
2 cents worth as usual
Jim Sharkey
