Old 01-12-2018, 02:23 PM
rv8ch rv8ch is online now
Default pmag manifold pressure tees
I ordered lots of different Ts (tees?) to try to find something good for the manifold pressure tubes, and finally found some that I think are excellent.
https://www.ebay.com/itm/251886532058
Mickey Coggins
http://rv8.ch
Old 01-12-2018, 04:43 PM
yep thats one way to do it.
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 01-13-2018, 10:09 AM
DrillBit's Avatar
DrillBit DrillBit is offline
Yowza! I just got a blister pack of plastic tees from the local NAPA auto parts. We are not worthy!
Kurt Haller
P-town, CA (10 min from KLVK!)
N748PK, RV-9A
In final assembly...
VAF dues paid 5 Dec 2017
Old 01-22-2018, 09:51 AM
YvesCH YvesCH is offline
Tom
What would be the other option?
Yves - Basel, Switzerland
RV-8 QB #83458 in Progress
Aerosport IO-360, Catto 3 blade, G3X Touch
HB-YUA reserved
Donation 2018 done
Old 01-22-2018, 12:50 PM
John Tierney John Tierney is offline
I started with a small brass from the hardware store but eventually went back to plastic over concerns of vibration causing the tee to wiggle and break the tubing.
John Tierney
Salem, WI
RV-7A - Finish/FWF Kit
N70JT Reserved
Old 02-20-2018, 10:07 AM
I ended up milling and turning a Tee as I had already mounted the original sensor block. So now I go from the primer port on Cyl. #3 with the original hose vans sends with the FF Kit to a bracket which supports the bulkhead fitting. From ther with 1/4 tubing to my new tee and then to the sensor block. In the Pictures the last piece of tubing is not yet finished and will get a relief bend.
HB-YUA reserved
Donation 2018 done
Old 02-20-2018, 12:16 PM
N941WR's Avatar
N941WR N941WR is offline
Yves -
How are you going to set the timing? We have discovered it best to blow in the MAP line above the Tee, so it sets them both with the same puff of air I am not sure why but customers who have flown with the EICommander will often get Timing Divergence Alarms when they are set one at a time.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-20-2018, 12:19 PM
N941WR's Avatar
For my installation, I used a Tee for drop irrigation tubing. 10 years later it is still holding up.
Bill R.
SC86 - Easley, SC
